player as media server
thuchien
thuchien Posts: 103
edited March 2011 in Electronics
Is there any blu-ray player out there that can function as WD HD live? Which can play all kind of video format and ISO file from hard drive. I know oppo can't play ISO file. thank a lot.
Sony 60" XBR2
PIONEER SC 05
Samsung BD-UP 5000
7.1 SETUP
Infinity P-FR with 12" build in sub
Infinity P-CC
4 Infinity P QPS
Kef sub 4000
pure av PF60
3 cobalt speaker cables
Post edited by thuchien on
  • Willow
    Willow Posts: 11,232
    edited March 2011
    I use the Ps3 and works great
  • Glowrdr
    Glowrdr Posts: 1,103
    edited March 2011
    I don't own a PS3, but I believe they won't play .ISO files?
    Your best bet is to just get a DLNA compliant device and adapt. There are some pretty good <free> programs out there to convert files, but you will most likely find that most of the files will be supported by the DLNA specification. Just my .02
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • thuchien
    thuchien Posts: 103
    edited March 2011
    Look like I will buy an other WD TV. I have one right now. I love it a lot, except for its home network stream with not working so well. thank a lot.
    Sony 60" XBR2
    PIONEER SC 05
    Samsung BD-UP 5000
    7.1 SETUP
    Infinity P-CC
    4 Infinity P QPS
    Kef sub 4000
    pure av PF60
  • nhhiep
    nhhiep Posts: 877
    edited March 2011
    I've been searching for the same solution, and so far, sadly but none. I've been running XBMC, which is crazy good, but there aren't any good/cheap remotes for it. I ended up buying 2 WD TV LIVE for $95 shipped last night.
