Blade / Blade SDA Cables (x2)
lasdaguy
lasdaguy Posts: 31
edited March 2011 in Wanted (WTB) Classifieds
Looking for two SDA cables with blade blade connector. PM if you have any for sale.
Post edited by lasdaguy on
    Toolfan66 Posts: 17,329
    edited March 2011
    Call Polk Tomorrow they will hook you up...
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • lasdaguy
    lasdaguy Posts: 31
    edited March 2011
    Strange, I did. The rep said they didn't make them anymore. Is there someone in particular I should be calling?
  • Big Dawg
    Big Dawg Posts: 2,005
    edited March 2011
    I may have an extra - I'll check tomorrow
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    Ben
  • lasdaguy
    lasdaguy Posts: 31
    edited March 2011
    ben62670 wrote: »
    Hey Ben,
    I appreciate the link. If possible, I'd like to get the originals just for the sake of being weird.
    edited March 2011
    Did you tell them it was a Blade/Blade?? I purchased one from them about a year ago or so..
    If it's an original one you want from back in the day? Then maybe someone will have one like big dawg, cause the one Polk would have for you today will be like the one ben said you could make, same connectors.
    SVS SB16 X2
  • ben62670
    edited March 2011
    lasdaguy wrote: »
    Hey Ben,
    If you can solder you can make a better one than stock. The stock one is a light gage wire. You should use 14ga wire and you will have a better cable than stock.
    Ben
    Ben
