AC Power extensions & power cables.......
For Sound Quality:
OCC (Ohno Continuous Cast) 12/3 copper, w/copper shield power wire.
Industrial spec. Pass&Seymour 5262i (Ivory).
Marinco 5266 male plug (brand new).
All components are used (the Marinco male plug is brand new).
I pulled a Furutech FI-11Cu male and Cu receptacle and installed the Marinco and P&S.
I used this in a second system for a while, so there may be some scuffs ect.
It is not perfect.
I put new heatshrink on the Marinco.
The length of the cable is roughly 1ft 10" long.
Anti-vibration/isolation:
Steel faceplate
Rubber under receptacle mounting points.
Aluminum box.
RFI/EMI:
Copper shield.
Ground:
Copper shield is connected to ground on male plug (drain).
Grounded to both receptacle and aluminum box.
Advantages:
Turns 1 outlet into 2.
Hydra 2 into a Hydra 3 for instance.
I used it on a Furman AC215 (Amp, Preamp, CDP).
Lower 48 states only.
Paypal (gifted with no fee to me), and US Postal money order are the only type of payment accepted.
$35/shipped!
Everything on below is brand new.
DH Labs Power Plus internal 12ga wire silver soldered to a Oyaide silver/rhodium IEC input cup.
Pass & Seymour 5362 (20amp) Industrial spec. receptacle.
Easily accepts "spikes" on the tabs shown.
The receptacle would run you $20, the Oyaide IEC input $14 (+ S&H).
$40/shipped!
Always making power cables.
These VH audio style cables sound fantastic.
Cryoed Wattgate IEC and Marinco Male.
14 day money back, minus shipping back to me only (1 way).
$65/shipped (up to 5 foot).
Same terms as above.
12/3 Cyroed Wattgate with Marinco male.
$45/shipped.
It is not perfect.
Steel faceplate
Aluminum box.
RFI/EMI:
Copper shield.
Ground:
Advantages:
$35/shipped!
$40/shipped!
$45/shipped.
A true 20 amp double.
2-Pass & Seymour 5362 (20 amp), with Hubbell 20 amp IEC.
Wired internally with VH Audio Cryoed 12 ga power cable.
Everything is brand new.
$50/shipped
Testing
Testing
Testing -
The 20 amp Double has SOLD!!!!
Everything else is still available.Testing
Testing
Testing -
This has been traded!
No longer available.
Only the top one and power cables are still available.Testing
Testing
Testing
