How to tell difference btwn Model 5 and Model 5Jr??
starkiller
starkiller Posts: 2,723
edited April 2011 in Vintage Speakers
Picked up a single polk today with no info on the rear whatsoever. It does have a fuse though. So, how do i know if its a 5 or 5jr??
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited March 2011
    I 5 has a wider cabinet and the PR is larger than the driver. The 5jr is fairly narrow and the driver and PR are the same size.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
    Toolfan66 Posts: 17,366
    edited March 2011
    Ron Temple wrote: »
    What Ron said!!!:cool:
  • stubby
    stubby Posts: 723
    edited March 2011
    Early 5 Jr's were ported and have a fuse. Later Jr's were treated to a 6.5" passive and Safety Guard. They were actually called 5 Jr.+ Hope this helps.
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • brgman
    brgman Posts: 2,859
    edited March 2011
    i have a pair that is labeled 5JR but has equal sized driver and PR,no port,and no fuse.
    I guess an early version of the + ??
    I’M OFFENDED!!!!
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited March 2011
    brgman wrote: »
    I have a similar pair... they didn't put the + on the exterior label, but usually it's stamped on the label stuck to the back of the drivers.
    There was also a 5Jr + Series II that used one of the trilam tweeters (SL2500). If the tweeter says Silver Coil Dome with a clear plastic cap it's the 5Jr+, if it's all black it's the Series II.
  • starkiller
    edited March 2011
    It says silver coil dome and the passive is bigger, has the fuse, no port...so..??
  • Ron Temple
    edited March 2011
    M5...
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • starkiller
    edited March 2011
    Thanks, now to find another orphan!
  • brgman
    brgman Posts: 2,859
    edited March 2011
    Yep
    Mine has the silver coil dome.Thanks for the info.
    I’M OFFENDED!!!!
  • starkiller
    edited April 2011
    hmm, guy on ebay has a M5, but it has no fuse...ok to pair up with my orphan?
  • dorokusai
    dorokusai Posts: 25,577
    edited April 2011
    The Junior model gets upset when you talk about the other model and constantly reference what he's done wrong musically compared to his loudspeaker Dad.
  • starkiller
    edited April 2011
    All righty then!!!:biggrin:
  • gdb
    gdb Posts: 6,012
    edited April 2011
    You want accurate record keeping ? Buy German made speakers.:biggrin:
    heiney9 Posts: 25,221
    edited April 2011
    starkiller wrote: »
    5B before they started using a polyswitch in place of the fuse. Gold logo or sliver logo on the grill? S/B silver.
    The same version I have. Uses same drivers as the 5B with polyswitch. MW6502.
    EDIT: The date says 1992 on the driver because it's later replacement. The other driver is original and says 1985 or 1986.
    edited April 2011
    starkiller wrote: »
    As long as it has the sl2000 and isn't a series II; it's the same speaker. They replaced the fuse with a poly switch.
