Technics SL-1301
Cayuga
I'm looking for a TT for my son, it will be paired with Yamaha CA-800 and a pair of Monitor 7's. I've found a Technics SL-1301 for $70, is this a good fit and is it a good buy on the TT? I checked the threads for info on the TT, couldn't find any info. Thanks
Post edited by Cayuga on
Check out Vinyl Engine (http://www.vinylengine.com/phpBB2/index.php) for lots of info. They have manuals in the library which should be helpful. I have the semi-automatic SL-1710mk2 which I like very much. There is less to go wrong than on a fully automatic turntable like the SL-1301, an important consideration with thirty year old turntables. The SL-1301 has quartz lock direct drive which is rock solid compared to the servo controlled direct drive turntables. But if everything works properly on the SL-1301 then $70 is a good price.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
Thanks for the site info, I'm just starting my homework.
I have an SL-1301 I purchased new in 1978. So far so good.
I'll keep you posted ...Marantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Technics SL-1301/Shure M97xE
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Antec VERIS A/V Cooler x 2 -
That's a very good price for a 1301 that is in good working condition. I've had a 1700 since 1977 and it still works just as it did when it was new. The dust covers are usually cracked near the hinges but that doesn't mean a lot if they still go up and down. Your son should be very happy with your choices.TO ERR IS HUMAN. TO FORGIVE IS CANINE.
