Amp vs Surge Protector
stangjason
stangjason Posts: 341
edited March 2011 in Electronics
Is it a bad idea to hook an amplifier (say a B&K Video 5 rated 5x100wpc) into a surge protector? If it's ok to use some surge protectors how do you tell which ones are ok to use?
Thanks,
Jason
Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1
Post edited by stangjason on
  • Flip8812
    Flip8812 Posts: 11
    edited March 2011
    Not only should you consider the current rating of the Amp and surge protector but also the in rush current of the amp when powered up. I have seen many amps go south due to to little current. I used an underated supply and when I turned up the gain other equipment on the strip would actually turn off and the surge would sound the alarm.
  • w_coyote
    w_coyote Posts: 66
    edited March 2011
    I have my amp(adcom 5503) plugged into my surge protecter(monster mkii 1100 I think) and haven't had any problems with it.
  • stangjason
    edited March 2011
    Flip8812 wrote: »
    I figure the amp and the DirectTV box to trigger it would be the only two items plugged into it. The rest of my electronics will stay on the HT surge protector I have them on.
    Here is the rating of the surge protector I may use.
    Specifications
    Continuous Duty Electrical Rating: 120V~/15A/60Hz/1800W
    Maximum Energy Dissipation: 1080 Joules . H-N: 360 Joules
    . H-G: 360 Joules
    . N-G: 360 Joules
    UL Clamping Voltage (3-line): UL 1449 400V
    UL Listed to U.S. and Canada Safety Standards: UL 1449, UL 1363
    Oh and thanks for the reply. I was beginning to think everyone on here knew about as much as I do about this stuff.
  • Flip8812
    Flip8812 Posts: 11
    edited March 2011
    Since you mentioned Direct tv box..... I would Strongly look at a protector /arrestor on the phone and coax line. I have spent 20+ years in the field and I would say 90+ % of surge damage doesnt come from AC line but from low voltage lines (phone, coax...).
    1800W continuous - What is the Amps and the DTV consumption? I assume you are well under this but I would double check the amps rating. Most ratings are either Max or Average that part can be a bit harder to determine.
  • stangjason
    edited March 2011
    Flip8812 wrote: »
    Yeah I have a phone line protector on my other surge protector but I may need to check and ensure they are hooked up. I'll have to look for teh B&K and DTV boxes consumption ratings.
  • stangjason
    edited March 2011
    I can't find a B&K Video 5 manual but I did find the B&K AV5000 which may be similar.
    The current of the AV5000 is rated Amps=28, peak-peak=14.
    Voltage Gain: 28
    Line Power, Fuse: 120VAC, 12A Slo Bio
    Weight: 35lbs (B&K Video 5 is heavier I believe and older if that's any indication of something).
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    An amp should be plugged directly into the wall. Nearly all manufactures will tell you this.
    Ben
  • stangjason
    edited March 2011
    ben62670 wrote: »
    Yeah I suppose I'll leave it on most of the time or tell my wife to hit the power button on it if she wants sound. She's more open to hitting a power button vs using the 4 remotes we have.
