getting a svs friday
i should recieve my new svs friday.is there any break in time or can i pound some tunes right away.
yamaha rxv663
csi a6
rti a7
fxi30
dsw pro 400
soon a svs
Post edited by john Jarvis on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited March 2011
    Calibrate first...then pound.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • packetjones
    packetjones Posts: 1,059
    edited March 2011
    Which SVS are you getting? I am interested in the pc12-nsd and the sb12-nsd.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • DollarDave
    DollarDave Posts: 2,575
    edited March 2011
    Ron Temple wrote: »
    And wear your jockstrap.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited March 2011
    Stretch your face muscles first so you don't get perma-grin.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • john Jarvis
    john Jarvis Posts: 18
    edited March 2011
    PC12-NSD DSP. i can't wait!!
  • john Jarvis
    edited March 2011
    well it came a wow what a nice surprise!!!!!!!!!!!!!!
  • thsmith
    thsmith Posts: 6,082
    edited March 2011
    congrats. Obsess about getting it setup right and you will not have to touch it again unless you change your room setup.
  • ken brydson
    ken brydson Posts: 9,061
    edited March 2011
    thsmith wrote: »
    +1. Love my SVS...
  • slammin86
    slammin86 Posts: 238
    edited March 2011
    Pound away...lol. New subs are fun.
    Receiver: ONKYO 709
    Amplifier: Acurus A200x3
    Front: EmpTek E55Ti
    Center: EmpTek E56Ci
    Surround: EmpTek E5Bi
    Sub: Elemental Designs A5-350
    TV: LG 55"
    Blu-Ray: PS3
  • thsmith
    edited March 2011
    People are probably tired of hearing me talk about using Room EQ WIzard aka REW but it will remove all doubt that your sub is set up right.
    txcoastal1 Posts: 13,519
    edited March 2011
    thsmith wrote: »
    pioneer mcacc mic, REW software, and a laptop
  • Obsession18
    Obsession18 Posts: 191
    edited March 2011
    I have a PC-12NSD, your going to love it! Go to radio shack and get a SPL meter, use it in conjunction with your receiver’s set-up to dial it in. I like to run mine about 3 or 4 db hot (compared to other channels) for HT. I used to use it for music when I was running a pair of Rti10's (turned the sub back down to flat) and it integrated very well.
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
  • thsmith
    edited March 2011
    I have a PC-12NSD, your going to love it! Go to radio shack and get a SPL meter, use it in conjunction with your receiver?s set-up to dial it in. I like to run mine about 3 or 4 db hot (compared to other channels) for HT. I used to use it for music when I was running a pair of Rti10's (turned the sub back down to flat) and it integrated very well.
    Here is the problem with that approach. You are only matching the peak frequency you sub is producing with your mains.
    You need to find the best placement to raise any dips and you need to clip the peaks and ideally end up with a fairly flat measurement across the frequency your sub is covering, say 20hz-100hz.
    Then run your AVR calibration.
    Here is an example of a nasty dip at 70-80hz and peaks at 40-45hz and 60-65 hz.
    Using your method the SPL is seeing the peak 65 hz which is 13db higher than 33hz.
    edited March 2011
    txcoastal1 wrote: »
    Sorry this was supposed to be worded in a question about REW...can you use REW with pioneer mcacc mic, REW software, and a laptop????
  • thsmith
    edited March 2011
    no you can not. Hometheatershack.com describes the different SPL or MICs you can use which they provide a calibration file for.
    This link describes what is needed.
    http://www.hometheatershack.com/roomeq/wizardhelpv5/help_en-GB/html/gettingstarted.html#top
    I use Turtle Beach Audio Advantage RSM sound card.
