amount of power i need
hippiewithaplan
I have two 10" polk GNX104's and a 12" kicker comp. rms is 50-175 watts and peak is 400 watts. what size amp would work the best and what brand. i currently have a 500 watt four channel amp and a 180 watt jvc head unit.
Post edited by hippiewithaplan on
sorry to break it to you, but using two different brands of subs will sound bad...and using 2 different sizes will sound worse...
-Cody -
what if i take out the kicker? what size amp would i need for the tens for it to sound good and get the most out of them?(the rms and the peak were for each ten)
yes, do not mix the 10's and the 12... you'd need 2 amps to do it, or just the exact right power ratings / impedance subs and chances are i'm betting you don't as it would be tricky for me to even do if i could hand pick the stuff to use for it... and yes, it would probably sound like junk.
the 500 watt 4 channel will probably work -- if it is 250 watts rms x 2 bridged at 4 ohms then that's fine for two 4 ohm GNX 10's.
otherwise, if its not... then you need an amp that is either 200 or so by 2 RMS at 4 ohms (whether this is a bridged 4 channel or a stereo 2 channel) or a 400 x 1 watt rms at 2 ohm mono amp.
suggestions... these are in no particular order... for the price, i'd buy the mtx 4250D -- its a good little amp, and it'll do the power you need -- its more than half off due to closeout... if not that, then the profile 600M -- mono's will be easier to use than 4 channels
- Profile CA 600M: 400 x 1 at 2 ohms / $169 / www.crutchfield.com
- Profile CA 650: 225 x 2 bridged at 4 ohms / $159 / www.crutchfield.com
- Profile CA 440: 180 x 2 bridged at 4 ohms / $129 / www.crutchfield.com
- Coustic 481QE: 225 x 2 bridged at 4 ohms / $289 / www.sounddomain.com
- Lightning Bolt B2.400.4: 200 x 2 at 4 ohms / $179 / www.sounddomain.com
- Hifonics Nemesis NX 440: 200 x 2 at 4 ohms / $205 after rebate / www.sounddomain.com
- Coustic 401DB: 400 x 1 at 2 ohms / $209 after rebate / www.sounddomain.com
- Rockford 351M: 350 x 1 at 2 ohms / $249 / www.sounddomain.com
- Lightning Bolt B2.350.1: 350 x 1 at 2 ohms / $179 / www.sounddomain.com
- MTX 4250D: 350 x 1 at 2 ohms (more like 400-ish) / $129 on closeout - last year's model) / www.sounddomain.com
- MTX 421D: 450 x 1 at 2 ohms / $299 / www.sounddomain.comThe Artist formerly known as PoweredByDodge -
thanks for the help
