360 Elite - HDCP Link Not Found Error with Netflix
PrazVT
So I have my 360 connected to a HDCP compliant 23" Samsung LCD (2048 x 1152) monitor via hdmi -> dvi. Just noticed that when I try to play Netflix movies, the screen goes to the giant XBOX 360 Logo and I get a "HDCP Link Not Found" message.
Though I can play netflix through my computer, I don't have it running all the time. Also, I'm pretty sure it worked fine at some point. Anyone else having any HDCP issues? Even the nVidia control panel in Win 7 is showing that my Monitor is HDCP compliant.
Not a big deal..but just doesn't make any sense.
ALL BOXED UP for a while until I save up for a new place
Home Theater:
KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
2 Channel:
Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs
Home Theater:
2 Channel:
Post edited by PrazVT on
Maybe what happens is the Netflix thinks when is sending the signal truth a DVI connection they think you are trying to pirate the streaming , but to tell the truth i heard more of this problem with non HDCP compliant tv`s and ppl had a way around just switching the cables from HDMI>DVI to component , but in your case its a monitor , maybe its following the same rules .
Yeah I think you are right. For whatever reason, MS doesn't think HDMI -> DVI connection is HDCP compliant enough.ALL BOXED UP for a while until I save up for a new place
Home Theater:
2 Channel:
Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs -
Its more Netflix end regarding what i asked at the xbox support . we in Canada are fairly new with Netflix but the same problem came up in the beginning with guys that they were using there monitors without HDMI .
Ahh okay. Well, considering all the crap they have to deal with in terms of complying with all the DRM type stuff, I'm not surprised.ALL BOXED UP for a while until I save up for a new place
Home Theater:
2 Channel:
I had a customer call me on this last week and I couldn't get a solution for him. He had an x360 with an Onkyo 607 receiver and a samsung TV. We installed it in December and it worked great for 2.5 months only to stop one day. I figured it was the x360/netflix but I don't know. Anyone have thoughts?Never kick a fresh **** on a hot day.
