Opinions/experience with Snell speakers?
Timothy Smith
I recently bought a set of Snell Type J-III speakers from a guy in Chicago on a lark.
I knew the woofers had rotted foam surrounds so I had those redone. Then it turns out both of the tweeters were bad too so I found a pair of replacements on e-bay and put those in. Probably have more $'s into them than I wanted to at this point, but stuck with it.
Pretty conventional, small floor standing/big bookshelf. Ported box, 8" Vifa woofer, 1" Vifa tweeter. Nice looking crossover and wiring inside.
Hooked them up to a little Cayin TA-30 tube amp and can't stop listening to them. Very musical, detailed, non-fatiguing. Not even broken in yet.
I am thinking about moving up the Snell line and buying some nicer ones if I can find them.
Anyone else tried Snells?
Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
Basic but solidly engineered two way.Not sure if that revision was the work of P Snell or K Voecks.
