looking for more power
john Jarvis
john Jarvis Posts: 18
edited March 2011 in Electronics
get a new amp or reciver? looking at the rx-v2065 or some used adcom or emotiva in the same power range?
yamaha rxv663
rti a7
csi a6
fxi 30
Post edited by john Jarvis on
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited March 2011
    For me the Yamaha
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    Do a search for amps. The topic has been beaten to death lately.
    Happy hunting.
    Ben
    Ben
  • ben62670
    edited March 2011
    Ben
  • leftwinger57
    edited March 2011
    Sorry I hit the wrong button. For me the Yamaha RX-V665 is a real contender in the 90wpc avr arena. Of course it has it's own little quirks but as an avr in the $400 range I do not see that many other examples .Now for some of the little things I don't like,It has preordained sound fields which only seem to add varying degrees of echo , reverb, and house settings from around the world. I do not like the volume scale that goes from-65 to + 20 I believe. Now all the good, it's a versitle amp that does have power to back it up. It is mostly up to date w/ all HDMI fittings and any other ports you might need.You can h/u a dedicated dock which I do and tunes play all day long.Very important it has pre-outs to h/u an external amplifier and use it as its own pre,also for H/T 90wpc is plenty and has the ability to go to 7.1 and add a zone 2 for an another room independant of what's going on in your main listening area.One other feature which did come into use was the protection circuit which when either pushed to hard, get to hot, or hit a frquency it did not like the amp shut down and this is exactly what is supposed to happen. All in all for price point, H/T apps and power provided
    I 'm of the opinion you will like this avr....lw
