Speaker Wire
Jack A
Jack A Posts: 77
edited March 2011 in Vintage Speakers
New to forum, Is it okay to solder the speaker wire tips for placing into the speaker binding post?
Clarajack
Clarajack
Post edited by Jack A on
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited March 2011
    You can do it if you want. It's called "tinning". However, it is hard to get the diameter correct or not cook the insulation. I prefer banana plugs or spades.
  • quadzilla
    quadzilla Posts: 1,543
    edited March 2011
    I'm a big bare wire fan. I use deoxit to keep oxidation away. No tinning. For convenience, I like crimped and soldered spades too, preferally silver over copper (not brass).
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • civilian
    civilian Posts: 357
    edited March 2011
    How big is big bore?:biggrin:
    ________________
    2 Channel-Denon AVR-4520/SDA 2.3TL's
    5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/
