Capacitors
jim 249
Hi All; I have read many posts here on xover rebuilding. My 2.3TL's are about to get his upgrade. My questions are: The 5.8uf cap, I can only find 5.6uf, the 8uf cap, I can only find 8.2uf. I did not find any mention about the 750pf silver mica caps in the tweeter circuit. I am planning on using Daytons or other brands from parts express. Cost is a factor for me. Any help; Thanks! :biggrin:
Post edited by jim 249 on
I think you can scrap the 750pf silver mica caps.Speakers: SDA-1C (most all the goodies)
While it would be nice to have "exact value" caps, keep in mind that the originals were something like 10% tolerance to begin with.
When replacing with 1% or 3% tolerance caps, A 5.6uf is easily within the usable range for the 5.8uf original cap, just as the 8.2uf is close enough for the 8uf.
I used Dayton and Erse brand caps on my SDA 1Bs; Dayton 1% for the high-frequency crossover circuitboard, and Dayton 5% and Erse 3% tolerance for the low frequency board. -
You say cost is a factor, but not what your budget it. If you contact sonicraft, you can get custom value caps at no extra charge. For example, the 2 sonicap 5.8s I got for my TL conversion cost 14 each, which is about the same as a 5.6.
Yes, you can just remove the 750 pf cap. That was there to bypass the so-so poly cap in the original network. I left it out of mine and got much better sound.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
yep-- call Sonicap,,Jeff or Elliot,,, they are great folks and they'll work with you--+1 on the 750 silver mica--de-solder and remove it,,nothing goes back in it's place.Have fun.JC approves....he told me so. (F-1 nut)
Is there enough room on the 2.3TL board after the new caps are installed to also fit a 10 ohm and a 12.5 ohm mills resistors hooked in series to replace the original 22.5 ohm resistor? Thanks for all the help so far!
A 22r will be fine.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Yes it can be done,,jerry and I did a set last yearJC approves....he told me so. (F-1 nut) -
Also you can mount the resistor on the bottom of the board.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
