LS70 Update
Earthy
I was planning to update the XO in my CS350LS with a Dayton 5.6cf Cap.
I am thinking while I'm at it, I should update my LS70's as well with a Dayton 6.8cf. What else should I consider doing?
Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808
Post edited by Earthy on
Replace all resistors with Mills MRA12s in the same value. And maybe consider using sonicaps instead of daytonsTurntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Thanks Quad
I was looking at this older post
http://www.polkaudio.com/forums/showthread.php?t=73915&highlight=cs350
where Ben had done a CS350 and that looks like a tight squeeze for the Dayton cap. Looks like the Soniccap is slightly larger and would need alternate placement.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808 -
I concur with what Quadzilla said. I installed sonicaps in my LS70's and they sound better than ever. Good luck, you'll be glad you made the change.Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
Cambridge Audio 640C V2 CD Player & Dacmagic DAC
Rega Planar 3: Deep Groove Subplatter, P3 Motor
upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor. -
Clarity Caps would be another good choice.
StanStan
Main 2ch:
HT:
Other stuff:
I was speaking about the CS350 being a tight squeeze for the Sonicap. Look at the picture in link above and you can see the Dayton Ben put in there is touching the binding posts. I suppose I can hang it outboard a little.
I will definitely be using Sonicaps in my LS70's and replacing the one resistor with a MRA12. I'll get the single 5.6uF for the CS350 and make it work.
Thanks!Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808 -
Post pics of what you have and the xover. Might be able to suggest alternative placements. For example, maybe you could stand it up on end or something..... Sold my 350, so I don't have one to pull apart and look at.Turntable: Empire 208
Arm: Rega 300
SonicCraft order placed. Given their proximity I should have it in a day or two. I'll post pics when I begin the update for the 350. Might be a day or two later before I do the LS70's.
Having never looked in the 70's, will the XO be accessible by pulling the binding posts, or do I need to pull a speaker to get at it?Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808 -
Assuming no production changes and your LS70's are the same as mine, you'll be able to access the crossover by removing the binding post assembly from the back of the speaker. The crossover is attached to the other side of the plate. After an hour or so of disassembling, solder slinging, and assembling, both speakers were up and running.Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
