I got a new monitor today.
ben62670
ben62670 Posts: 15,969
edited March 2011 in Electronics
My old monitor is slowly dying on me. It is a 19" 4/3 The new one is a 1080 23". I actually like the size of the 19" more. Web pages are so spread out it makes it a pain to read. The reason I went with a 23 wide-screen is that I use it for a TV and also movies in my room. I also thought that games would play wide screen too, but FEAR doesn't. I don't know about others. Well the price was right ($150 shipped) and I hope to get used to it. Here is the link to where I bought it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009266
Ben
Post edited by ben62670 on
  • PrazVT
    PrazVT Posts: 1,607
    edited March 2011
    Very nice Ben. I have 2 of these Samsung 23s:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824001317
    They actually have a 2048 x 1152 resolution, which is still 16:9. Prompted my purchase of a GTX 295 when it was still king :). And I think they were only like $170 when I got 'em.
    I keep one at work - definitely helps with all the spreadsheets I work with. Still think 16:10 is better for computer stuff tho.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited March 2011
    Fear widescreen:
    Widescreen Support
    F.E.A.R. version 1.08 has full widescreen support for resolutions up to 1920x1080.
    Older versions of F.E.A.R. (First Encounter Assault Recon) do not have native widescreen support. To force a custom resolution go to the following directory 'C:\Documents and Settings\All Users\Documents\Monolith Productions\FEAR' and open the file 'settings.cfg' with a text editor (such as Notepad).
    The two lines we are interested in are "ScreenWidth" and "ScreenHeight".
    Change these to your desired resolution. For example, if you want a resolution of 1440x900, it should look like this:
    "ScreenWidth" "1440"
    "ScreenHeight" "900"
    Changing the resolution also changes the FOV so there is no need to do anything else.
    Please note, going into the 'Options > Display' menu will reset the resolution to 640x480.
  • ben62670
    edited March 2011
    Do you know the path in Win7?
    Ben
  • cokewithvanilla
    edited March 2011
    Try C:\[your user]\My Documents\Monolith Productions\FEAR
    Alternately search C:\users for settings.cfg
    I don't have fear :/
  • ben62670
    edited March 2011
    Found it. Much better than before. I have slight jitter with the candy turned up, but this is an older card. GeForce8800GTX 756meg.
    Many thanks
    Ben
  • ben62670
    edited March 2011
    Spend the extra money and get the ASUS. The colors on this one just aren't that vivid. It gets great reviews, but I just don't see it.
    Ben
  • fbm211
    fbm211 Posts: 1,488
    edited March 2011
    Hmmm.have you played around with the hard to navigate (at first)on screen adjustments.It took me a couple days to get mine the way I liked it.I have the G24Hbmid olympic model and love it.I did set mine to cold instead of warm too. I also had a 19" sony that started to die after 10 years.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • newrival
    newrival Posts: 2,017
    edited March 2011
    For all around use where you don't need 2560x1600+ resolution (like photo processing, etc.), here's a pretty nice monitor I've had great success with: Samsung XL2370. It's LED backlit so it's contrast is great. I ended up buying 3 for home. I'm with you, Ben, on the 4:3 ratio and have that on my Dell S-IPS panels in my studio. The real estate is so much more useful for getting things done.
  • cokewithvanilla
    edited March 2011
    ben62670 wrote: »
    Does your monitor have a matte screen? Many of the monitors with glossy screens are more 'vivid', but less color accurate.
    have you calibrated the monitor?
    As far as aspect ratios, my favorite is 16:10... I think 4:3 or 5:4 monitors are fine for spreadsheets and such, but if you're doing video/photo editing or playing games I think the wider screens help... not 16:9 wide though.
    EndersShadow Posts: 17,707
    edited March 2011
    Another to look at is this:
    http://www.amazon.com/HP-2509m-25-Inch-Diagonal-Monitor/dp/B002MT6SDU/ref=sr_1_1?s=electronics&ie=UTF8&qid=1299619107&sr=1-1
    I have had mine for about 9 months and its quite good. Its not LED backlit though, but its good enough for me.
    Wish I had the cash for a Dell U2711 or some of the higher end NEC monitors
  • ben62670
    edited March 2011
    I just adjusted it for "graphics" in the menu. It is better now, but the brightness needed is almost full up. I just don't see getting many years out of this. I'll mess with it some more, but I still recommend the ASUS for a few $ more.
    Ben
