rca input on adcom amp-not working!!Please Help!!
K-daugh
ok the left front rca input(female) only work if i push down on the the rca(male) of the interconnect wire, while its plugged in....As soon as i let go it stops working.Really baffling me because the amp is less than a year old it looks brand new ...not one scratch on it ...all other channels work fine..i tested the wires they all work ...
What is the reason for this and is it something i can do myself. right now i have a zip tie around the male connector and then around the binding post directly underneath it ..so its good for the moment...its really bumming me out though ive only had the amp for less than a week ....
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
Custom Jumpers
Post edited by K-daugh on
Sounds like a bad / cold solder joint.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
thats what i was thinking so how would i fix it?Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
Can you solder? If not should be a quick and cheap fix for someone who can solder.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »Sounds like a bad / cold solder joint.
could it be possible that the solder joint broke....for some reasonBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Custom Jumpers -
so take the top off of the amp and is the solder joint visible...its an adcom 7605....after the top is off just hit it with some solder and a soldering iron....do i need to prep it in anyway ....im gonna need someone to walk me through this...lol i love club polk by the wayBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
How far are you from Windham CT?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Im in billerica,ma 01821Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
You are about an hour and a half away. If you can't get it you could bring it down and I could fix it for you.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
google maps says im about two hours away....i have faith in myself that i can take care of it...i am really good with my hands ive done some simple soldering...i just need some directionBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
If it is like the 7500 you may have to pull the module out to fix it. Pop the top and you will see.
MapQuest said 1:40 for the trip. Sometimes these programs lie!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
i will need to ask a friend to borrow his soldering iron
but ben think i can shoot you a pm and you can maybe walk me through it...or am i making this more complicated than what it actually isBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Custom Jumpers -
Just pop the top. You'll see what needs to be done. Also make sure the caps are discharged. My GFA-7500 nailed me.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
ok ben thank youBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
So I'm going to radio shack today (its local) to buy a soldering iron.....any suggestions on what kind and also what kind of solder ....I'm gonna give this a whirl myself..like I said I have minimal soldering expereince in highschool but I do have experience with soldering copper pipes for plumbing ....so hopefully I. Can figure it out ...I will post pics before during and after ....any advice would be appreciated thanks guys and thanks again benBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Bump what kind of soldering iron to get from radioshack ....yes I'm very persistent I knowBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Don't use plumbing solder, use electronic solder. You can get that from Radio Shack also.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Would silver solder work or should I just get the basic electronic solderBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Yes and it's even better.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
just picked up a radio shack 20/40 dual heat soldering station ...pretty nice unit cant wait to play with it ....got some silver bearing solder too!!!!i love toys lol:biggrin:Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Good luck and remember never have iron on Printed Circuit Board as the heat can left the copper trace. You may wish to practice some first.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
