powerd sub
Awais yaqub
Can I connect powered sub woofer when my amplifier output impedance is 3 ohms
And speakers are also of 3ohms and 90watts (dav-c770) can I connect 165 powerd sub to them via speakers output
Pakistani
Post edited by Awais yaqub on
Can you say that again?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
this is not answer of my question man with beutifull ****'d wife !!!!!!!!
learn too use mindPakistani -
I'm curious to know what amplifier this is and why it has it's own resistance:rolleyes:
davc sounds like a SONY model #, a home theater package I believe, and I'm wondering what happened to the sub that came with it? how is it hooked up? -
Hi Scott...More later,
Tour...
Vox Copuli
Tour....
FINALLY SOMEONE AGREES WITH ME!!!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
its sony's dvd home theater sacd system with nearlly no bass so i want to add powerd subwoofer
speaker impedence= 3ohms
rcevier impedence= 3ohmsPakistani -
Does your system have a subwoofer preout? If not...you can add a powered subwoofer by speaker wire. But you won't gain all that much volume I wouldnt think......:rolleyes:
Bye Scott- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
