DC offset!
lanchile
Wow, I just checked the dc offset of my Bryston B60-R and I got an steady 03.4 mV right channel and 03.5 mV left channel. That is amazing how low and well "matched" they are.
Make it simple...Make it better!
Post edited by lanchile on
Nice amp
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
yeah, it is a very well handmade int-amp.Make it simple...Make it better!
20 yr warrantee, why not? Bryston is solid.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Wow very nice.
Most likely DC servo circuit is used as in any newer Bryston.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
I have been chatting with James from Bryston and may need to order a B-60R SST. It seems like it could be a good match with my Fortes, the warranty is obviously second to none, and I'm tired of messing around with the tubes on my 300B amp (with the most recent case of likely losing its rectifier tubes).
Actually James theres no servo or adjustment for that matter,it's just the result of close matching of the input differential trannies.I have a 2BLP which is basically identical to the amp section of the B60.Most likely DC servo circuit is used as in any newer Bryston. -
Thanks Fred! I stand corrected as I am not very familiar with the Vintage Bryston. I must say the matching is pretty good since the DC offset measures are in a few mV after all these years.
Good ol' Day Analog Electronics indeed!Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Yeah, you can say that again lol. My Bryston B-60R integrated amp is still up to specifications as when it was new 12 years ago... Bryston uses some of the best components available. with Bryston you get what you pay for...Quality all over.
