Music Rig speakers setup help need (4 x Rti38 vs 2 X LSi 9/7)
malikarshad
malikarshad Posts: 527
edited August 2003 in Speakers
Hi Guys,
I'm currently setting up another speaker system to be used with my pc and mainly for music. I have connect the digital out of my audigy sound card to receiver.
I have currently hooked up like this
Fronts - Rti 38's
Center - none (do i need one? if yes CSi40 or CSi30)
Surrounds - Rti' 38's
Sub - SVS 20-39pci
Receiver - JVC RX-8020
I was thinking of changing it to 2 channel with Lsi 9/7 hooked to SVS 20-39pci.
I guess the cost of both setup should be equivalent as I have spend $450 on four Rti38's + $220 on Receiver = $670.
Please give your input whether I should go for 2 channel with LSi9/7 OR stick with the Rti38 setup. I've never heard the LSi 9/7 so I cannot decide.
BTW I'm still waiting for my pb2+ for my HT. When that comes I'll use my 20-39 pci for music rig.
Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
Sub - JTR Captivator S2 (Dual 18")
Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
  • organ
    organ Posts: 4,969
    edited August 2003
    Unless you're upgrading from the JVC to seperates, I suggest sticking with your RTi set up. Why don't you add the LSi to your HT? Maybe an external amp for the mains after the speakers.
    Maurice
  • faster100
    faster100 Posts: 6,124
    edited August 2003
    your useing that setup for your pc? seems like alittle over kill?
    what do you use the pc for? 2 channel rig is a good idea, but full surround on a pc, and you already have a deticated HT, not sure i follow
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • malikarshad
    edited August 2003
    I use my pc mainly for gaming & music. I have logitech Z560(4.1) system but after builiding up my HT system I did not enjoy it anymore. The sound seemed to weak. So I decided to try out some Polk speakers & that really make a big difference in sound quality. Since I had a 4.1 setup with Z560 i connected 4 speakers and I also tried 2 speakers but 4 Rti38 sounded the best.
    Last night I tried my center CSi40 from my HT to my computer rig & that sounded even better. But I'm not sure if Csi40 would be an overkill for this setup.
    Maurice
    Maurice good idea but its too late now and no $$$ to spend. Would have considered if CircuitCity had LSi's. In my area here in TwinCities, MN there is no dealer I'm aware of that carries LSi's.
  • dorokusai
    dorokusai Posts: 25,661
    edited August 2003
    That is a nice setup, yea the CSi40 is overkill for the computer, IMO.
    I found that the real speakers route on computer audio is outstanding. Especially with a high-speed sound card. I have the Audigy, and it is great.
    It sounds like that kind of setup is what you like, so go for it with the RTi38's and add a CSi30. Turn the game on a get your guns blazing, :)
  • malikarshad
    edited August 2003
    More photots
  • malikarshad
    edited August 2003
    More photos
  • malikarshad
    edited August 2003
    Thanks for you input dorokusai:)
    I got the CSi30 today from the Circuit City and they sound great. You were right CSi40 is an overall kill.
    I really luv my rig now. Its sounds awesome with Polk Rti & Audigy.
    Thanks for all your input and help
