To Biwire or not to Bi Wire
brentman0110
Can someone explain the whole bi wire thing to me? I have a CSi40 as a center should I bi-wire?
Post edited by brentman0110 on
Best thing to do is to try bi-wire and single wire. Use the one that SOUNDS BEST TO YOU. My LSi9's sounds better bi-wired with my NAD amp and they sound better with single wire runs with my Dynaco amp. If you decide not to bi-wire, make sure you replace the jumper plates with speaker cables.
Try doing a search on bi wiring. There has been plenty of discussions on this topic in the past.
Maurice -
Agreed!
Only thing you can do is try it for yourself and see what you think. I bi-wired my RT800i's and the CS400i and liked the outcome.
There are a TON of threads that say one way or the other, in the end its what ever you the listener like.Front
Polk RT800i (BI-wired)
Rear
Polk RT600i
Center
Polk CS400i (BI-wired)
Sub
SVS 25-31PCi (22Hz tuning port)... it's SubHuman
Receiver
YAMAHA RX-V1400
TV
Mitsubishi WT-46807 HDTV
HD receiver
T i V o HR10-250
