DVD Player with SACD capability?
TennMan
I have been kicking around the idea of getting a new DVD player. I'm not looking to purchase anything high dollar just an average player. I've noticed that some of them have the capability to play SACD disks. Before coming to this forum a few weeks ago I had never heard of SACD. Is that something that is on it's way out or the coming thing for music CDs?
My system is primarily used for listening to music but I still want to be able to watch a movie now and then so I do need a DVD player since the old one has quit working. Should I select a DVD player that is capable of playing the SACDs?
Thanks for any information.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Post edited by TennMan on
Yes. I do believe that there is a universal player in the FM now. Let me go check real quick.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
there was a similar thread that might we worth reading on this:
http://www.polkaudio.com/forums/showthread.php?t=116321"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
FAAAAk, my bad. That player does not play SACD's. Thanks EndersShadow. I missed the model # by 1, literally. I was thinking the 2910.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Thanks for the info. I'm still not up to speed on the SACD format. Could someone enlighten me on the pros and cons of SACD please? Are disks still being produced in that format? I see they are more expensive. Are they worth the extra cost for a low end system like I own?
They sound better.
There are no cons.
Yes.
Yeah, so what?
Doubtful.Political Correctness'.........defined
President of Club Polk -
Wiki is your friend. Just look it up. Essentially SACD resolution is FAR superior (if recorded well, to most other digital formats) see Wiki chart below.
SACD is a disc of identical physical dimensions to a standard compact disc; the density of the disc is the same as a DVD and it encodes audio using a process known as Direct Stream Digital. The SACD sampling rate is 2.8224 MHz and the resolution is one bit. A stereo SACD recording can stream data at an uncompressed rate of 5.6 Mbps, four times the rate for Red Book CD stereo audio.[2] SACD recordings can have a wider frequency and dynamic range than conventional CDs.
CD
Format 16 bit PCM
Sampling frequency 44.1 kHz
Dynamic range 96 dB
Frequency range 20 Hz – 20 kHz
Disc capacity 700 MB
Stereo Yes
Discrete surround Never implemented
SACD
Format 1 bit DSD
Sampling frequency 2.8224 MHz[2]
Dynamic range 120 dB[2]
Frequency range 20 Hz – 50 kHz[2]
Disc capacity 7.95 GB
Stereo Yes
Discrete surround Yes
There are three types of SACDs:[2]
Hybrid: The most popular of the three types, hybrid discs include a Red Book layer compatible with most ordinary Compact Disc players, dubbed the "CD layer," and a 4.7 GB SACD layer, dubbed the "HD layer."[3]
Single-layer: Physically a DVD-5 DVD, a single-layer SACD includes a 4.7 GB HD layer with no CD layer.
Dual-layer: Physically a DVD-9 DVD, a dual-layer SACD includes two HD layers totaling 8.5 GB, with no CD layer. It enables nearly twice as much data to be stored, but eliminates CD player compatibility. This type is rarely used.Currently orbiting Bowie's Blackstar.!
denon 2900 does play sa-cd.... i would know.... i have owned it... has 3 separate modes as well to push all its concentration to strictly audio playback
oh and it has a pretty blue LED on the front that lights up when you put a sa-cd in it. really cool mood lighting lol
some cheap free sony speakers
psw125
denon 1610
3.1 channel because i hate cables ran across the living room like that -
Damn, my double bad. I clicked the link and read that it did not, then posted back.
Tell you what. I'll just shut my mouth and say that SACD rocks. That I do know about.
Sorry, I was just tryin' to help the fella.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
The Sony BDP-S470 plays SACD and so do some others in the line.Fronts: Polk RTi A7's
Center: Polk CSi A6
Surrounds: Polk TSi500's
Subwoofer:Polk DSW Pro 500, Emotiva Ultra 12
Amplifier: Emotiva XPA-5
Processor/AVR: Emotiva UMC-1
DAC: Emotiva XDA-1
CD player:Emotiva ERC-1
Blu-Ray: Oppo BDP-93
Turntable: Kenwood KD-500
Tonearm: Polk-Mayware Formula 4
Cartridge: Shure M97-XE
Television: Sony KDL-55EX500 -
depends on the SA-CD. i dont care for the DSOTM sa-cd. however Brothers In Arms roxorz my boxorz like WHOA. there are some NICE selections for sa-cd, if you are willing to pay the extra, and sometimes its certainly worth it.
psw125
denon 1610
Thanks guys for all your comments. I will do a little research on which SACD player is in my price range and will keep the one in the FS forum in mind. I think a SACD player makes sense now that you guys have gave me enough information about it to help me understand what it's all about.
Thanks again!- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
Thanks again!
that 2900 is going to beat anything in that 200 price range unless someone is basically giving away another player.
psw125
denon 1610
Sony 9000es,,,,,Pioneer Dvi79,,,,,,,,Oppo 980HLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
i meant to put in "going to be hard to beat", my apologies... and then comes availability. that sony is a nice unit as well
psw125
denon 1610
The Dark Side of the Moon SACD is better than any other format...I should know I own it...like that makes any effin difference but just matching moronic posts.
Just remember nobody likes their baby called ugly and you will be fine.
RT1 -
reeltrouble1 wrote: »The Dark Side of the Moon SACD is better than any other format...I should know I own it...like that makes any effin difference but just matching moronic posts.
RT1
yeah, i hate my copy in sa-cd. maybe i didnt let the disc burn-in properly
psw125
denon 1610
hehehehe.......
RT1
