A&B outlets
beric
Can I connect TSI200 to both A&B outlets on my NAD c372. It seems to improve bass responce.
It doesn't do anything for you. Your TSi200 only has a single set of binding posts so you can't even biwire your speakers. I'd suggest just getting a single set of good speaker cables.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
If you like it,by all means,do it.I mean,it's your stuff and you're the one that has to listen to it.If you can't hear a difference, don't waste your money.
