MIT Shotgun S3 ICs 1M
Polkitup2
MIT Shotgun S3 ICs 1M. I bought these new from Joe Abrams in August, 2009. They are in excellent condition.
$250 shipped to CONUS only. Payment is Paypal as a "gift".
Post edited by Polkitup2 on
I'll take these if still available.
They are, I will PM you with my paypal addy.
Sold
Payment sent. Looking forward to trying these IC's as they should be a step up from what I'm currently using.
You are in for a treat. Using them between your favorite source and preamp.Speakers: SDA-1C (most all the goodies)
So you would recommend using between source and preamp? I wasn't certain if I should do as you recommend or run them between my amps and preamp. I'm using a Denon 3910 as source, Bel Canto Pre1 as Preamp, driven by Adcom GFA 565 mono blocs.
cjmustang69 wrote: »So you would recommend using between source and preamp? I wasn't certain if I should do as you recommend or run them between my amps and preamp. I'm using a Denon 3910 as source, Bel Canto Pre1 as Preamp, driven by Adcom GFA 565 mono blocs.
I started my journey with the Shotgun S3.3's connected to my source and preamp. After burning them in, I decided to purchase another set to connect from my preamp to my mono blocks.
Play with the setup (one pair) and use them according to your ears.
You are really in for a treat.
Congrats and enjoy. -
I plan to do exactly as you say. I know these cables are spoken highly of in this forum - so I'm pretty confident they won't be the last set of MIT ICs I purchase. Most likely will lead to a set of MIT speaker cables also. I've been using Signal and lower end Audioquest ICs and speaker cables to date. Really looking forward to hearing what the MITs do for my system.
Try souce first as most likey you will see more improvement there vs pre and amp.Speakers: SDA-1C (most all the goodies)
