Sub Out or Pre Out????
bryanr72
bryanr72 Posts: 53
Should I hook up my woofers on my RT2000i to the Sub Out on the back of the receiver, or hook them up to the 5.1 RCA Pre Out Left & Right connections on the back of the receiver? Am I correct in thinking if I hook them up to the Pre Outs, I will have stereo bass in the fronts? I have the fronts set to Large, and the Center/Surrounds set to small.
At this time, I'm not interested in bi-wiring.
-Bryan
Equipment Used:
AVR: Sony STR-DA3000ES Digital 7.1
Front: RT2000i
Center: CS400i
Surround: f/x500i
Surr. Back: FXi50
Floor Sub: Infinity BU2
Post edited by bryanr72 on
  • goingganzo
    goingganzo Posts: 2,793
    edited August 2003
    yes use the sub out with is the same as the 5.1 out with is the .1 out. or set your mains to largeand just leav the jumpers on.
  • bryanr72
    bryanr72 Posts: 53
    edited August 2003
    Wouldn't I have the benefit of having lows in stereo, and having the .1 going to the center/surrounds?
    This is probably a stupid question, but if I leave the jumpers on, does the amp power the subs on the RT2000i, or does each amp in the tower power the subs??
    -Bryan
    Equipment Used:
    Front: RT2000i
    Center: CS400i
    Surround: f/x500i
    Surr. Back: FXi50
  • goingganzo
    edited August 2003
    the jumpers will just feed the sigonal to the sub amps so that is y you need to put them on large. you will get all the lfe ment for the mains but wont get the .1 bass. but the part where you can run into trubble with ht is when yopu start adding more than 1 spot where the bass comes from you can get nasty nulls.
  • bryanr72
    bryanr72 Posts: 53
    edited August 2003
    So I should triple split them out of the Sub Out and set all my speakers to small...thus sending .1 to the towers and the floor sub?
    -Bryan
    Equipment Used:
    Front: RT2000i
    Center: CS400i
    Surround: f/x500i
    Surr. Back: FXi50
  • bryanr72
    bryanr72 Posts: 53
    edited August 2003
    goingganzo, where did you get the PolkAudio sign hanging above what looks like your Atlantis movie poster?
    -Bryan
    Equipment Used:
    Front: RT2000i
    Center: CS400i
    Surround: f/x500i
    Surr. Back: FXi50
