USB ->SPDIF Converters
falconcry72
falconcry72 Posts: 3,580
edited March 2011 in Electronics
I'm looking to improve my 2 channel rig, and I think my next step lies in the source. See my sig for specs. I will continue using my computer at all costs, so I'm just trying to find a better way of getting the signal out of it. I have been using an ASUS Xonar Essence ST soundcard with a SPDIF out to a Parasound DAC-2000 Ultra. That soundcard has about as good of a SPDIF out as you can get in a computer. I have been thinking of trying a USB DAC instead, to try to eliminate the jitter that may be inherent with using the soundcard, but it seems you have to spend over a grand to get a decent asynchronous USB DAC. I've looked at the dacmagic and other less expensive units, but while they may get the signal out better than my sound card, I would imagine that their inferiorities to the Parasound DAC would negate any benefits.
Sooooo, now I'm looking at asynchronous USB to SPDIF converters. The idea is that it would get the signal out of the computer as truly as possible, and then I could use my Parasound or any other standard DAC. It would greatly widen the DAC options, especially on the used market.
I don't want to spend more than a couple hundred bucks. A few I'm looking at:
http://www.m2tech.biz/index-3.html
http://www.musicalfidelity.com/products/V-Series/V-LINK/v-link.asp
Here's a website that lists a bunch of different models:
http://www.thewelltemperedcomputer.com/HW/USB_SPDIF.htm
So what do you think? Is this avenue worth persuing? Am I going to have to spend big bucks to get an improvement, or will the $170 Muisic Fidelity unit do the trick?
Thanks for the input.:smile:
Post edited by falconcry72 on
    heiney9 Posts: 25,426
    edited February 2011
    I have a Musiland Monitor 02 that does an excellent job and comes with some very nice software. Very nice piece, well built with a discrete power supply section.
    http://www.head-fi.org/forum/thread/443786/musiland-monitor-02-us
    Pacific Valve sells them stateside, but they are about $50-60 more than you can buy them for direct from China. I was skeptical, but this thing works as advertised for USB to SPDIF conversion. It's also a dac, but I've haven't spent much time with it as a dac.
  • blueboxer
    blueboxer Posts: 621
    The new Arcam rDAC offers an asynchronous USB and is only about $500. If it sounds anything like their signature sound, it may be a winner.
  • falconcry72
    blueboxer wrote: »
    that is an interesting looking DAC, but it doesn't have a SPDIF out. I'm looking for a USB to SPDIF converter so I could use any number of non-USB DAC's with it.
  • falconcry72
    heiney9 wrote: »
    That's a good looking unit. I'll definitely add it to my list. I think it's now between that musiland monitor 02 and the music fidelity vlink. It's nice that the musiland does have a DAC, so you can use it as a DAC in a pinch, if your primary DAC craps out, or in a future unseen application etc. But I like that the vlink is asynchronous, and I have more confidence in the Music Fidelity name, but that doesn't necessarilly mean anything. hmmm.....
  • falconcry72
    Question: if you have two USB DAC's hooked up to your computer simultaneously, would a signal go to both of them? If so, I could get both, hook'em both up, switch back and forth on the Parasound DAC, and then return the loser.
    The Musiland is async as well (or I wouldn't have been interested). They have some slick software to and it can pass up to 192k signals. MF is good gear as well, but this thing has really surprised me and it's so flexible.
    Read the headfi link I posted, but it will take you a few days as I think there are over 100 pages. Very, very informative.
    Good luck
    Musilands software will allow that. Typpically I'd say no unless the software supports it.
    Let me rephrase that.....you can switch between the Musiland dac section and any dac you have hooked up via the USB/SPDIF conversion.
    Another great thing is it works with W7 64bit some of the software for other companies is behind, I think. Not sure about the MF or what it supports.
    Musiland support ASIO which is about the best, IMO.
  • falconcry72
    heiney9 wrote: »
    Read the headfi link I posted...H9
    Started reading. Very informative; very long.
    What I find the most interesting right now is that macrog, a seemingly learned individual and the first big proponent of the 02 in that thread, says that the 02 outperforms his soundcard for getting a SPDIF signal out of his computer, and his soundcard happens to be almost identical to mine.
    Async USB is superior to most sound cards because the USB greatly reduces jitter. I wasn't necessarily 100% convinced but now I am. USB is superior to a mounted sound card in a computer. Plus, it's so much simpler to run properly (outside of Windows kernel mixer, etc), IMO.
    It's just one of those neat, well made devices that has grown on me and I tend to be pretty picky, even for a computer office rig.
  • falconcry72
    H9, how would you compare using the musiland monitor 02>SPDIF out>external DAC vs. using a quality CD transport>SPDIF out>the same external DAC?
    Don't know, this is strictly for my secondary office rig. I've only used my dac with a computer. My old computer I used a Chaintech soundcard with optical out. The new computer doesn't have a digital out so I use the Musiland to convert the USB to SPDIF to the same dac.
    I have a straight USB dac made by Populse, but I don't think it sounds as good as my AMC DAC8 so I needed a way to convert USB to use it.
    I use a Squeezebox Touch music server for my main rig. I have an upgraded external power supply and I use it with a heavily modded Adcom GDA 600 and control it with my Android phone.
  • bikerboy
    bikerboy Posts: 1,230
    edited March 2011
    Have you seen the Hiface? http://www.enjoythemusic.com/magazine/equipment/0210/m2tech_hiface_usb.htm
    Seems like a good way to get great digital out of a pc.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
    edited March 2011
    bikerboy wrote: »
    I don't care that it runs off USB power. I am a BIG believer in having a nicely designed and isolated power supply.
    EndersShadow Posts: 17,696
    edited March 2011
    heiney9 wrote: »
    Just curious on this converters DAC. It is one you would recommend as a dual workhorse both to convert USB to RCA and also use as a external DAC? I have been in massive debates about possibly getting an external DAC and then moving to powered studio monitors in my office (my new desk will be very tight on space). I only use my computer as my source.
    Since I can only use the coaxial digitial audio (SPDIF interface is broke on the motherboard), this seems like a really good viable option to run between a set of KRK Rokit 6's, or AudioEngine A5's. The other option I was looking at would be a M-Audio Firewire Solo. I would then use 1/4" TRS Male to XLR Male connections for the speakers. Not sure if one is prefered over the other...
    More than likely I would have to control volume with my computer and I am not sure if thats the recommended method or not...
    edited March 2011
    Since I can only use the coaxial digitial audio (SPDIF interface is broke on the motherboard), this seems like a really good viable option to run between a set of KRK Rokit 6's, or AudioEngine A5's....
    I am currently using a Musiland Monitor 02 and it has really surprised me, not only because of the flexibility but it's performance. A big plus is it has it's own software. And it's asychronous which is what one should look for in a USB device of this type.
    http://www.pacificvalve.us/MusilandMonitor02.html
    If you do a Google search you will find a lot of info.
    edited March 2011
    It's really not recommended but everyone has to cofigure their system within the constraints fo what they are trying to accomplish.
    The ASIO driver will not allow the computer to control the volume for any of these types of devices, but there is a work around. There may be other options if you are running W7.
    edited March 2011
    heiney9 wrote: »
    How do you think it would compare to something like the M-Audio FireWire Solo?
    edited March 2011
    Have no idea since I'm not at all familiar with that. There is a lot of info available on the 'net so I'd get my read on. That's pretty much how I arrived at my choice.
  • drselect
    drselect Posts: 664
    edited March 2011
    heiney9 wrote: »
    H9, I tried loading ASIO diver to my computer this past weekend to use with media monkey and I finally thought I got it right but I am still able to control the volume from the tool bar on the bottom of the screen. Based on your comments above do you think I have the ASIO drivers loaded correctly?
    I am using vista 64 and sending the signal to my AG NFB-3 DAC via USB and I have selected the ASIO driver in the MM output device.
    Sorry to OP if this is to off topic.
    edited March 2011
    drselect wrote: »
    Sorry, it took me long enough to adapt to Windows 7 64bit. I know nothing about Vista or it's driver scheme. Best to hit the 'net and doing some reading. That's how I have been learning about W7 and a few issues.
    The Musiland came with supporting drivers and they work fine. If your unit didn;t come with supporting drivers then the internet is your friend. One of the main reasons I went with the Musiland is the driver support.
    Wish I could be of more help, but for me it's about reading, and a bit of trial and error, and some help from my brother who is an IT person.
    I would say no, you don't have them loaded correctly if you can still control the volumes via the computer.
  • drselect
    drselect Posts: 664
    edited March 2011
    You have been a help. If it wasn't for another post of yours I don't know if I would have known what ASIO is. Looks like I need to do some more googling. I think you posted in another thread but can't find it what you are using for for playback MM, winamp, foobar?
    Thanks again.
