Monitor 5jr
TrashyTrucker
Hey all,
Got ahold of a pair of 5jr's (no passive) (ported)
Q: Need a 1.3ohm resistor. I forgot what values in parallel to come up with that value?
Q: this has the sl 2000. Is the rdo 194 a drop in replacement?
Thanks in advance,
Matt :biggrin:
Thanks in advance,
Matt :biggrin:
Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears...
Rotel RCD 1520 cdp
biamped to:
Post edited by TrashyTrucker on
reportedIntegra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
biamped to:
...SDA's are just like candy for your ears... -
2.7 ohm paralleled with another 2.7 ohm gives 1.35 ohms total.
Yep, the 194 is it.
G~Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS-II (modded)
Infinity RS-IIIa (modded)
Infinity RS 2.5 x 2
Magnepan 1.6QR (modded)
System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373 -
Yep, the 194 is it.
G~
Thanks Geoff,
I was doing some research on my srs 3.1 tl's and they also used a 1.3 ohm, and seems to me I had to run them in parallel as well. BTW you do fine work and document your builds well. Thank you.
Matt :biggrin:Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
biamped to:
You'll be fine with a 1.2r 12w Mill's
http://www.soniccraft.com/mills_resistors.htmPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Thanks Ben,
This xo is wierd. No board.
Rotel RCD 1520 cdp
biamped to:
It's a round board correct?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I hope these pics show what I mean, if they are poor in quality let me know. I do not imply that this upgrade will be difficult, just that it is different (no CB). Any comments or advice greatly appreciated.
Note: I do plan to upgrade to the rdo 194's.
thanks,
Matt :biggrin:
Rotel RCD 1520 cdp
biamped to:
I like point to point over a circuit board with a simple XO so no worries there.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Thanks BenIntegra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
biamped to:
BTW that will be cheap to mod with only a 12uf cap per speaker and 1 resistor
Also 2 resistors in series can be used to get the proper value. Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I have a pair of 5Jr's just like these that I updated recently. I used Dayton caps and resistors from P-express. I ordered 1.2's but they sent 1.5's. I was impatient and put them in anyway since I just use them for surrounds. Sound improved immensely, highs seem to be not as overwhelming as before. I have SL2000's all the way around in my 5.1 system. I do use Audessey on an Onkyo 807 receiver that integrates them very well with my SDA's in the front. Was worried about the tweets being toned down too much with the 1.5's but they work good for my application. I'm happy with them so far after a month of constant use.
The 5jr's were my first Polks... way back in 2006. They had great sound for what they were... and for the $15 I paid for them at a thrift store.
Enjoy!Ludicrous gibs!
