Help! Word icon has gone missing.
Ron-P
Ron-P Posts: 8,520
edited February 2011 in The Clubhouse
The program is on the computer because I can open old "Word" docs but the icon for the actual program is no where to be found. It's not in the main menu, not in the Microsoft Office tools nor is it on the desktop. I cannot find it anywhere. Any idea on how to get it back?
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
  • ben62670
    ben62670 Posts: 15,969
    C:\Program Files (x86)\Microsoft Office\Office12
    Then find the WinWord.exe and right click on it. send to desktop(create shortcut) and you are done. From there you can drag it into your programs directory, or place it where ever you want.
    Ben
    VR3 Posts: 29,399
    just search for microsoft word - should pop right up, right click and copy to desktop
  • Ron-P
    Ron-P Posts: 8,520
    I went to the C drive, then into Program Files but cannot find any WinWord.exe file.
    If...
  • Ron-P
    Ron-P Posts: 8,520
    Oh, I've tried searching, nothing comes up.
    If...
  • Ron-P
    Ron-P Posts: 8,520
    What I did do was open an old file, clear out it's contents and save it as "Microsoft Word" and moved that shortcut onto the desktop. It works, for now anyway.
    If...
  • mdaudioguy
    mdaudioguy Posts: 5,165
    +1 for ingenuity! :smile:
  • ben62670
    Ron-P wrote: »
    You have to go into a few more folders than just program files. I posted the full path above. Also it may be word.exe depending on version.
    Ben
  • Ron-P
    Ron-P Posts: 8,520
    Got it! Thanks.
    If...
  • ben62670
    Was it labeled word.exe or winword.exe?
    I knew you could:smile:
    Ben
  • Ron-P
    Ron-P Posts: 8,520
    winword.exe
    I had to look in some obscure file to find it.
    If...
