Pics of my new ATL pure copper wall outlet
fbm211
Im getting ready to install my new ATL-1000cu and thought Id share a pic of it.
Really good construction and the free brushed aluminum power plate looks real nice.:biggrin:
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
forgot to upload.:eek:SDA-2BTL with custom IC
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Hey--that thing looks well built--mind if I ask--what did something like that cost?JC approves....he told me so. (F-1 nut)
http://mojo-audio.com/ATL-1000cu-Cryod-Pure-Copper-Receptacle-ATL-1000cu.htm
They have it listed for $99.95. -
thanks for the link--how are those Taylos ?JC approves....he told me so. (F-1 nut)
george daniel wrote: »Hey--that thing looks well built--mind if I ask--what did something like that cost?
You can get it at cryo parts for $103.50 and shipping is $5.00.
So for 108.50 you get the ATL and the power plate is free for a limited time.
Not a bad deal since the plate is listed at $45.00
And lee cryos them both.SDA-2BTL with custom IC
It's cool that they label it with the ground plug up. Now I feel vindicated in having installed even my cheap Leviton outlets in that orientation.
Yeah.And all the outlets in my place are installed that way also.SDA-2BTL with custom IC
It looks like Im going to have to hire an electrician to hook this up.I tried 3 different outlets and every single one wont pull out more than a 1/2 inch.I cant understand how the hell these things were installed except that thay may have installed the outlets first and then the drywall.
So now im considering just getting a dedicated 20 amp circuit run out from the breaker box and into my apt.The box is right outside my door so I wont need a very long run and Ive seen some of this type of installation before.A long metal tube is run down the wall and connected into the outlet that is usually built into a box.
So now if I may ask....What sort of high quality wire /cable should I get? I imagine I need to get some in wall certified stuff.Right?SDA-2BTL with custom IC
If you have the option, add a 20a circuit for your outlet. Since you mentioned you're in an apt, run it by the complex first. My complex was totally cool when I wanted to redo switches and add some outlets. Just make sure you hire a certified electrician and have any changes documented.
And yes, outlets are installed way before drywall gets put up.- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
Thanks sal.What brand would be a good choice for audio grade.
I like this cardas stuff but its way to expensive.Link> http://www.dedicatedaudio.com/inc/sdetail/14230SDA-2BTL with custom IC
