4 or 8 ohm connection for SDA1-cs
jmitchnh
jmitchnh Posts: 31
edited February 2011 in Vintage Speakers
Just picked-up a new tube amp and it has both 4 and 8 ohm terminals. Since the SDA-1Cs are rated at 6 ohms, just wondering which one would be the proper/better choice? Thanks!
Life's too short too listen to bad speakers
Post edited by jmitchnh on
  • Schurkey
    Schurkey Posts: 2,104
    Try 'em both, see which one works better.
    My money is on the 4-ohm tap, but what do I know?
  • xsmi
    xsmi Posts: 1,798
    I would say 4 ohms because this is nominal impedance. The impedance will drop below 6 most of the time so go 4 ohms for the most stability.
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,186
    I use the 4 ohm taps on my tube amp on my 1C's.
    SDA SRS 2.3TL's
    SDA 2B TL's
