Decided to make my own LP storage
del44
del44 Posts: 686
edited February 2011 in DIY, Mods & Tweaks
This should make easier access to my LP's. The flash makes it look lighter than it is.
Each bin (8) should hold about 75-100
I mad the center storage for extra cart., tonearms, sleeves, cleaning supplies. etc.
Nice saw for cutting plywood.
  • Systems
    Systems Posts: 14,872
    "In please", great Karma!:biggrin:
    VERY, VERY NICE!
    Great work!
    Testing
    Testing
    Testing
  • newrival
    newrival Posts: 2,016
    wow, super nice work!
  • fishbones
    fishbones Posts: 947
    Cool dude! Nice work...
  • quadzilla
    quadzilla Posts: 1,543
    veruh, veruh nice....
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • greyford1979
    greyford1979 Posts: 749
    Nice work man! So when are you going to karma the saw?:tongue:
    I love animals, they're delicious!
  • helipilotdoug
    helipilotdoug Posts: 1,230
    Very nice work! Looks fantastic! :smile:
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • m1aman
    m1aman Posts: 143
    Great idea!
  • [Deleted User]
    [Deleted User] Posts: 1,223
    Nice work. The saw is the same brand as the table saw at Polk Audio. Used it many times, wished I had one of my own. :cool:
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    That is gorgeous man. What type of materials did you use as far as wood and staining? I'd like to try a smaller version with just the 4 big bins for LP's. Also what are the dimensions of the finished piece.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Nice work I'm impressed. Now that table saw makes mine look like a toy.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • del44
    del44 Posts: 686
    Thanks for the kind words
    That saw isn't going anywhere. If anyone is wondering what type of table saw this is. It's a dual blade slide saw. The first blade is smaller and rotates in the opposite direction of the main blade. This eliminates any kind of blow out or splintering of the plywood or melamene.
    TNHNDYMAN wrote: »
    Everything is oak. I stained it to match my existing cabinetry. Measurments for each opening in the 2 main cabinets are 15.5 X 14. The width accounts for 1" for the drawer guides (heavy duty) and 1" for the sides of the drawer 1/2" each side).
    The cabinets are 24" deep and 33.25 tall (including 3/4 top) Drawers are 22"deep. Pretty standard measurements. I kept the bottom drawer 3" up from floor. All the exposed plywood is edge taped.
    Very nice work. Can't do anything like that myself. I just had a carpenter install some new Kitchen cabinets to match some 30 year old units because we had to put in a new Stove-top hood that was much shorter than the old one. This is a REAL SKILL...they look almost exactly like the originals. Your work is pretty close to his! As for me, I'm REALLY GOOD WITH PLASTIC MILK CRATES! lol
    cnh
    EndersShadow Posts: 17,765
    cnh wrote: »
    cnh
    My skills lie with cinder blocks and 2x4's :wink:
    Looking quite good. Makes me appreciate my uncles (who are carpenters) all the more....
  • Bassphil
    Bassphil Posts: 136
    Nice cabinet. I wish I had the tools!
  • del44
    del44 Posts: 686
    Having the space and right tools does make a world of difference. :biggrin:
    Here's a better view of the drawers.
