Cartridges Ortofon 2M Red vs 2M Blue, my thoughts
gfong
I upgraded my cartridge on my Pro-Ject RPM 1.3 Genie from an Ortofon 2M Red (approx 1 month old)
to an Ortofon 2M Blue.
Here are the specs of both cartridges.
Technical data:
2M Red features a tipped elliptical diamond.
Output voltage at 1000 Hz, 5cm/sec. 5,5 mV
Channel balance at 1 kHz 1,5 dB
Channel separation at 1 kHz 22 dB
Channel separation at 15 kHz 15 dB
Frequency range at - 3dB 20-22.000 Hz
Frequency response 20-20.000 Hz + 3 / - 1 dB
Tracking ability at 315Hz at recommended tracking force 70 um
Compliance, dynamic, lateral 20 um/mN
Stylus type Elliptical
Stylus tip radius r/R 8/18 um
Tracking force range 1,6-2,0g (16-20 mN)
Tracking force, recommended 1,8 g (18 mN)
Tracking angle 20 degrees
Internal impedance, DC resistance 1,3 kOhm
Internal inductance 700 mH
Recommended load resistance 47 kOhm
Recommended load capacitance 150-300 pF
Cartridge colour, body/stylus Black/Red
Cartridge weight 7,2 g
Replacement stylus unit 2M Red
2M Blue: features a nude elliptical diamond.
Channel separation at 1 kHz 25 dB
Frequency range at - 3dB 20-25.000 Hz
Frequency response 20-20.000 + 2 / - 1 dB
Tracking ability at 315Hz at recommended tracking force 80 um
Stylus type Nude Elliptical
Cartridge colour, body/stylus Black/Blue
Replacement stylus unit 2M Blue
Background: I went from an AT-LP120-USB Direct-Drive Professional Turntable (USB & Analog) with an upgraded AT120E/T Cartridge.
Pro-Ject RPM 1.3 Genie with Ortofon 2M Red:
First impressions right out of the box was that the noise floor was a little louder than what I was use to with my Audio Technica set up.
In fairness, the Red was right out of the box and the AT had 6 months use on it.
What I did notice was the clearer upper range from the Red. The tist tist tist from the cymbals and other instruments in that upper range
were more pronounced and enjoyable.
They were not at all bright or overbearing, but were pleasantly noticeable.
Mids seemed a little hollow/thin when playing some classical or solo piano/solo male voice.
I found that it lacked a little substance in that area, but again it could be from the recording I was using and the lack of hours on the 2M Red.
Bass is very tight and clean with the Red. It hits hard and the tom toms sound like they should as well as the other drums and bass lines.
It does very well with jazz and blues and is simply outstanding. The 2M Red really shone with jazz and blues.
The Red tracked adequately but I did notice a little inner grove distortion on some records. I am sure that once I had some hours on the cart,
it would settle down and maybe have gone away.
I tried a few older records and it played through them without missing a beat. No skips or jumps.
Sum Up:
Ortofon 2M Red cart shines and comes out swinging. Bass, highs and mids sound great.
Very nice cartridge that would suit anyone with an entry to mid level system. Rock, country, oldies, disco or jazz, the Red handled them all
with confidence and sureness.
2M Red Pros:
- excellent value
- defined highs
- tight bass
- clear and concise
- steady tracker
- upgrade to Blue with just stylus
2M Red Cons:
-a tad hollow sounding handling classical music or solo piano etc.
-some inner grove distortion (with break in may go away)
Pro-Ject RPM 1.3 Genie with Ortofon 2M Blue:
The Red cartridge had about a month of use on it compared to the right out of the box Blue.
Audio shop set-up the 2M Blue on my Pro-Ject with the Ortofon recommended weight of 1.8 grams.
(If you saw my other thread, my first 2M Blue cartridge was damaged and it is replaced now.)
I am able to compare these two styluses at the same time as the Ortofon 2M series use the same cartridge for the Red/Blue stylus.
Ortofon 2m line starts at Red and goes to Black (high end).
Very nice selling feature of the 2M series; if your Red gets damaged or wears out or you just want to upgrade, you can replace it with a Red or
step-up to the Blue stylus and vice versa with Bronze/Black using the original Bronze/Black cartridge.
Using the same system, records and volume I swapped the stylus back and forth to get my results.
MSRP: Red is $99.00 Blue is $199.00
As the Ortofon 2M Blue set down on the vinyl it was apparent that noise floor was reduced over the Red. It was quite substantial.
(My copy of Brothers in Arms is in nice shape, but has some noise at the first and in between some of the tracks.)
Ride Across the River the first track on the b-side of Dire Straits "Brothers in Arms" album started playing. I did not need more than 5 seconds
to realize that I made the right choice with the upgrade!
Ortofon had done their homework with their 2M line by providing us with cartridges that "actually do get better" the higher up we climb
in the 2M series ladder. You can hear and notice the improvements the moment you switch the stylus.
Whatever the 2M Red did great, the 2M Blue did a better job of it. The change was not night n day, like Wow this sounds so much different.
It was more Wow, the Blue sounds so much better at what the Red was already doing well.
More punch, quieter background sound, exacting highs with the mids fully filled out.
As for the AT-120E I really liked the quite noise floor, bass and mid sounds that it produced. With the 2M Red I liked highs and bass response.
Those strong points I heard from the Red and At-120E seemed all wrapped up in one package with the 2M Blue.
Well produced analog sound with pronounced bass, smooth mids and exacting highs.
The 2M Blue tracks well and I have not noticed any inner groove distortion. (Could have been factory setup of Red or newness)
2M Blue Pros:
-defined highs
-tight bass
-clear and concise
-steady tracker
-ups the ante over the Red
2M Blue Cons:
- none when compared to 2M Red
When comparing the 2M Red and Blue, there is nothing I can knock either stylus for; they both do things right! Standing on their own against
other like cartridges I would think they would shine.
Final thoughts:
Both cartridges do everything right. Bass, mids, highs, all sound great. If you are looking to step up the Red's performance
or your Red cartridge needs a refresh, look no further then the Blue.
Upgrading from the 2M Red to the 2M Blue will bring you a noticeable improvement in sound that will substantiate the one hundred dollar upgrade price.
Nothing worse then spending $200.00 on a new cart and find out that it sounds okay, or not much improvement! Tha will not happen with this uprade!
Are there better cartridges out there from Ortofon and other companies, of course there is.
I spent $500.00 on my turntable with included Ortofon 2M Red cart and thought I would upgrade to the next level Ortofon Blue cart for $199.00.
Does everyone that has an Ortofon Red need to go out and grab the Blue! No, not at all! The Red was doing everything right.
This hobby allows us to upgrade and I am glad that Ortofon has lines like the 2M, which allow us to go to the "next level" with our systems.
Would an Ortofon 2M Black blow the 2M Blue out of the water, it should! Am I going to find out? No, I do have a dollar limit on what
I think is a reasonable amount of money to spend on upgrades compared to the cost of the equipment.
My main focus was not to compare the Ortofon to the Audio Technica and I tried to stay away from direct comparisons,
as I feel the AT-120E is an outstanding cartridge that has done well for me.
My main goal was to see for myself and hopefully show others that if you upgrade from an Ortofon 2M Red to 2M Blue,
you will get a substantial upgrade that you will notice the moment the Blue hits the record.
Thanks for reading, Greg Fonger (gfong)
Technical data:
Sum Up:
2M Red Pros:
- excellent value
- defined highs
- tight bass
- clear and concise
- steady tracker
2M Red Cons:
2M Blue Pros:
-defined highs
-tight bass
-clear and concise
-steady tracker
2M Blue Cons:
Final thoughts:
Post edited by gfong on
Nice write up and comparison!
Excellent review. Thanks Greg.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Very Nice review gfong..
I just purchased a Pro-Ject Debut Carbon and it came with a 2M Red and my store offered an upgrade to the Blue for $89 extra..
I went for it just got it home and will post my thoughts when I get it all set up, have some shuffling around with my components to place the Carbon..
Thanks for the Review.
Oh just noticed your sig, from Ontario..
I as well, Whitby Audio was the store..ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
Great review! I have a 2m red and I wondered if an upgrade to blue would be worth it. I will put the blue on my wish list.
Thanks,
Albert -
Great review! Thanks.
The blue is still working great after many hours on the turntable. No complaints at all on the upgrade.
Jhayman: excellent price point on your 2M Blue upgrade, awesome deal! -
reportedATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables
thanks for the insight. I am debating a bronze or black but am told the Rega tables have a tough time with them due to the VTA sensitivity, but now I am more curious if I can do this.
I am just starting out with vinyl and exploring cartridge options so your review was very timely.
for a Rega table you might need to put a 2mm spacer between the tonearm and the plinth. I had my dealer do that for my RP-1 after i bought it because it came with an Ortofon OM5-e cartridge. I was gettin some rubbing along the bottom of the cartridge on new 180 gram records with the slightest warp before the modification was done.
BTW which rega table are you running?System Details:
Marantz SR 5010, Rega RP1, Marantz CD 5004, Denon DRR-680, Carver M-4.0t
Polk SDA 1C (modified), Definitive Technologies BP-10, Polk Audio CS400i
