- Muse 100 amplifier - Excellent
dee1949
..Muse 100 amp - Audiophile ...one of the BEST. Excellent condition.
.....$425.00 local pick up Washington DC 20017
- Hooked up for audition.
...if you are looking then you probably know what it is.
- DESCRIPTION :
Solid-state stereo power amplifier.
Power output: 100Wpc, 20dBW (8 ohms), 200Wpc, 20dBW (4 ohms).
VOltage gain: 30dB. Sensitivity: 890mV.
Absolute polarity: non-inverting. Input impedance: 51k ohms.
Distortion: less than 0.5% THD+noise.
Frequency response: ?3dB at 13Hz and 200kHz.
Output impedance: 0.6 ohms, 20Hz?20kHz.
Output current capability: 45A maximum, peak?peak into 0.1 ohm.
Power consumption: 90W idle, 600W maximum (limited by 5A line fuse).
Dimensions: 3.5" H by 18.9" W by 13.4" D. Weight: 28 lbs.
review below:
http://www.stereophile.com/solidpowe...use/index.html
http://www.audioreview.com/mfr/muse-...2_1583crx.aspx
- The Muse 100 is the top amp on the stand. Below the Muse 100 is the SCS amp (pro line of Muse) that was mentioned in the Stereophile article. The SCS is mosfet also and is 260 watts 8ohms and 350 watts into 4ohms. It is also for sale for $265.00. The "Sound Anchor" speaker amp stand is also for sale - $135.00 - can be used as a boat anchor - weighs over 50 lbs.
- DESCRIPTION :
review below:
Post edited by dee1949 on
Ekk, trolls!My 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012
