Bathroom scales
mdaudioguy
I have no idea why I would ask this here, except that I know I'll get some good answers! I'm looking for a decent quality, consistently precise bathroom scale. Not sure how much I'm willing to spend, yet - perhaps $50 to $100? I'm sure, like anything, the sky's the limit.
The cheapo I have now gives me a different reading every time I step on it, (+/- 2 or 3 lbs??) so I usually just average...
Anyhow, what do you guys have? I don't even know where to start (and don't say Google!). Looking for recommendations.
Post edited by mdaudioguy on
Mine is a Taylor I believe. Got it at Target. Lifetime warranty...good thing as I've already had to replace it. There are also days that I can step off/on and gain/lose a pound.
It was a cheapy $30 one, not sure of how their 'higher end' models rank.
mdaudioguy wrote: »I have no idea why I would ask this here, except that I know I'll get some good answers! I'm looking for a decent quality, consistently precise bathroom scale. Not sure how much I'm willing to spend, yet - perhaps $50 to $100? I'm sure, like anything, the sky's the limit.
I would keep it if it consistently lied in the minus!:biggrin:Testing
Testing
Testing -
I use my pants. If the waist gets tight I need to cut back on the food. If the waist gets to loose (hasn't happened yet) then I must be sick.
Actually, for the few times I weigh myself I use the scale at the gym.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
The one I got from K-Mart is so inconsistent it's useless... I'll have to look at the one we have at work (weight loss challenge). It seems to be accurate (unfortunately).Ludicrous gibs!
your weight will change from day to day. At the gym, they call it "water weight", though I don't know how precise the term is. +- a few pounds is supposed to be normal. I use the expensive scale at the gym and my weight fluctuates.
cokewithvanilla wrote: »your weight will change from day to day. At the gym, they call it "water weight", though I don't know how precise the term is. +- a few pounds is supposed to be normal. I use the expensive scale at the gym and my weight fluctuates.
Very true.. depending on who you are and how much you weigh, it can be +/- 5 lbs..2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
Make sure you get a 120v AC scale and then purchase a megabuck power cord,talk about precision !!!!If you can't hear a difference, don't waste your money.
Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
On it's own dedicated line as well. -
I let the carnies tell me my weight. They are pretty accurate.......then i go and get a fried dough.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
Any decent 'digital' scale will be fairly accurate. And as mentioned, weight fluctuates throughout the day, so take into consideration the TIME you weigh yourself. I find the first thing in the morning is more stable for me. After that it's all about food and intake and you can go up several pounds or less even if you are NOT gaining any permanent weight.
I got a "bathroom scale". Tells me all the time "Honey, you're gettin' fat." But it cops an attitude when I say "Really? You should look in the mirror!"Expert Moron Extraordinaire
:biggrin: You're living dangerously Jstas, but I guess you know that!
Ok, so I thought one of you out there would own the Cadillac of bathroom scales, and it would come highly recommended. I guess off to Target it is, to buy the best they've got!
Btw, I should have been more specific - I know my weight varies from day to day... what I was concerned about was that the reading on my scale varies from second to second! -
I have this at the house. Seems to do a pretty decent job. Got it at BB&Beyond
The only trick is you step lightly on it first, to activate it, then step off. The put both feet on it. Locks the weight after about 3 seconds (indicated by the weight flashing). Holds the locked weight in the display for about 30 seconds then turns off.
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
Scott
You need to eat more meat.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
dragon1952 wrote: »You need to eat more meat.
Not if he is really a she. :biggrin:"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Do you just want a scale? Or do you want to be able to measure body fat, etc?Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
I've heard some do that... is it accurate, or just a gimmick? Actually, accuracy in weight is first priority. -
I have it set to kilos so I look skinny when I weigh myselfWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
mdaudioguy wrote: »I've heard some do that... is it accurate, or just a gimmick? Actually, accuracy in weight is first priority.
I'm in the market for a good, accurate set of scales also. I've been on a rigorous treadmill workout since November trying to get from 200+ to around 182. I've seen these body fat scales and I would be rather leery of them. The problem with most basic body fat or BMI calculators is that they assume an ideal weight for you based on height, weight and age alone. In order to be halfway helpful you would have to be able to select your body type (ectomorph/endomorph/mesomorph) at the minimum, and it would have to give you an ideal weight range, i.e. 169-183. You would have to interpret your muscle mass (or lack thereof) and other unique things about your body and decide where in that range you fit.
By using one of the online calculators, at my height of 5'10", weight of 190, body type medium-large and age of 58 my range would be around 169-183. I factor in that I worked out for years and have above average muscle mass and figure I should be at the high range or somewhere around 180-183. There are other calculators that might just take height, weight and age into consideration and give me an unrealistic ideal weight of say 165 or 170. In order to get to that weight I'd have to lose 10-15 lbs of muscle.
I wouldn't put too much stock into a built-in calculator on a set of scales unless it let you input enough information, and then output an ideal range. And then I wouldn't find it that useful. Most of us can look at ourselves and figure it out anyway, or even just use a good online calculator.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
I found to not keep in the bathroom as the humidity kills them. I think they gave them the name so people would have to keep buying them. I have the old dial style that you have to zero out, but people have photos of the clear digital one that was tops in consumer reports. Health O Meter is mineOnkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar
