Do I need a cap?
JDOGG
would i need a cap for a 150x2 amp that is 450x1 bridged? the amp is a profile CA600.
Panasonic VIERA 46" 1080p plasma
Onkyo TX-SR805
Klipsch RF-7(bi-amped)
Klipsch RF-25
Xbox 360 with HD DVD
Playstation 3
Cobalt Cable
Onkyo TX-SR805
Klipsch RF-25
Playstation 3
Cobalt Cable
Post edited by JDOGG on
I would STRONGLY reccomend the Cap. i had a Profile A400XL bridged. Did not get any volume until I put a Cap on it. I would reccomend at least 1/2 Farad. Personally I would use a 1 myself.
Chris -
well what are you running it at?
150x2 or 450?
if its 150x2 then you dont really need it, but it wouldnt hurt
its its 450 then i would suggest a .5 farad cap, the rule for caps is 1 farad per 1000watts
-Cody -
i've got a half - a - farad on my grandfather's 425-ish watt amp... keeps the v-needle steady at idle... once the truck is up to like 1k rpms though its not doing much of anything.
but truth be told, you're prolly fine without it -- i'd still do 1/2 farad anyway though.
if you intend to add another amp in the future - just get a 1 farad now so you dont go and say "shizzle doggy fizzle why'd i buy only a half farad one?"
The Artist formerly known as PoweredByDodge -
Hell No...You dont need a Cap...
Thats all i'm gonna say. The Reggs now my stance on the wasted things...:rolleyes:
