HTPC uses?
keeneyrm01
keeneyrm01 Posts: 80
edited February 2011 in Electronics
I got an extra PC from my parents and don't want it to go to waste but I don't know what I can really do with it in my home theater. I was planning on just using it as a music server to connect with the other computers itunes libraries on my network.
Its an older dell computer with only a 60 gig hard drive, pentium 4 2.8ghz, 512mb ram. My tv (panny s1 plasma) and receiver (onkyo 807) don't have a VGA input so i'll have to use s-video. I can upgrade some components if it would be worth while but I don't know what I would really use it for... Whenever i watch downloaded videos i just bit torrent them then transfer to ipod then play though ps3 so it wouldn't benefit me there.
Any other uses for it let me know.
HT basement room:
TV- 42in Panasonic S1 Plasma
A/V Receiver- Onkyo NR807
Blu-Ray- 80GB Sony PS3
Power Supply- Monster HTS-1600
5 Disc Sony CD/DVD Changer
Time Warner HD Cable Box
Speakers:
Front- Polk RTi A3
Center- Polk CSi3
Side Surround- Polk RTi4
Back Surround- Polk RM6750
Sub- Outlaw Audio LFM-1 EX
Bedroom:
32in Visio LCD, Sony STR-DE685 AVR, MTX Monitor 12, Sony 5 disc DVD changer
Post edited by keeneyrm01 on
  • bobman1235
    bobman1235 Posts: 10,822
    Unfortunately "Ghz" and "MB RAM" don't tell nearly the whole story anymore, but I'm doubting it could do full HTPC duty if it's that old. If you already have a way to get video to your PC, barely seems worth the effort to me to try and retrofit something which may or may not do the job well.
  • newrival
    newrival Posts: 2,017
    I think you're going to have a hard time using it in your home theater for anything other than music. You certainly won't be getting any 1080p playback worth watching and even 720 is going to be rough. Also that hard drive is pretty tiny, I'd say if you stick a new HD in it, use it as a media server like you mentioned.
  • nspindel
    nspindel Posts: 5,343
    HTPC is more hassle than it's worth. If all you're looking to do is stream music, look at something like a squeezebox. For video, check out sagetv. I'm a big believer in keeping the computer in a back closet as a server, and then hooking up tcp/ip devices as extender hardware in your home theater.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I would think a HTPC maybe worth the trouble, if you like to call it that. But saying that I would suggest Win 7 OS and I don't feel what you got would work at all.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • renowilliams
    renowilliams Posts: 920
    I don't see any reason it couldn't be networked and used as a NAS box. If you have a DLNA compliant device like some Sony bluray player. You would need to add some larger drives. Now it will depend on the motherboard chipset as to how large a drive it will recognize but if it will see 1 terabyte drives it could work for this purpose. There is software out there IE: Freenas that can be loaded. This software has a built in bittorrent dowloader as well as HTTP and FTP serever capabilities.
    I know someone who has used a P4 box for this use. Anyway, food for thought.
    Tim
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • greg2350
    greg2350 Posts: 544
    I have used a pc running win7 32 bit using a P4 3.4 ghz with 2 gb ram and it was able to run windows media center just fine. Video was a gforce 6600gt using a DVI to HDMI cable.
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • spock 2054
    spock 2054 Posts: 163
    keeneyrm01 wrote: »
    It?s an older dell computer with only a 60 gig hard drive, pentium 4 2.8ghz, 512mb ram. My tv (panny s1 plasma) and receiver (onkyo 807) don't have a VGA input so i'll have to use s-video. I can upgrade some components if it would be worthwhile but I don't know what I would really use it.
    I revived an old P4 2.6 gig pc, and was using it for HTPC duty before snarfing a discarded core2duo from work. Your mileage may vary, but you might be able to extend the life of that dell.
    My office pc is a homebuilt 2.6Ghz P4, 3 gigs of ram, Asus 3650 AGP video card with 512mb, HT Omega Striker Sound card, LG HD DVD/BD combo drive, and close to 3 terabytes of storage. Running Windows 7. When this computer was in my living room, I took the video to the DVI input of my TV, and the audio out to my Onkyo 806 on a piece of digital coax. I was able to play back my backed up BD content with no problem from this box. The newer dell has a low profile Radeon HD 5450 that sends both audio and video over my network to my receiver via hdmi.
    Suggestions:
    Upgrade the physical memory of the computer. 512mb is barely enough to run XP. Since it is an older pc, memory could be pricey. 2 gigs or more is better.
    Upgrade the video card with 512 to 1 gig of ram, one that is HDCP compliant, and has a DVI out. S-video from a pc does not look that great. You can pick up an inexpensive DVI to HDMI cable from Monoprice. My guess is that your motherboard has an AGP slot, perhaps even a pci express slot. It would help if I had the model number of your dell and service tag so I could look up the configuration of your computer.
    Plop in a big hard drive. If this dell has SATA connectors, stick a 1tb drive in that box. You?d be surprised how quickly you can fill that drive with BD content! If no onboard SATA connector, then shop for a PCI SATA controller card. IDE drives in larger capacities are becoming difficult to find.
    Find a sound card with a coax or optical digital output - take the output to your Onkyo so you can enjoy Dolby Digital and DTS surround.
    Upgrade to Windows 7.
    Examples of Newegg prices
    PNY Optima 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR - $53.99
    SAPPHIRE 100288L Radeon HD 4650 1GB 128-bit DDR2 AGP 8X HDCP Ready Video Card -$79.99
    (This card needs its own power source)
    SYBA SD-SATA-1E1I PCI SATA Controller Card - $13.99
    DIAMOND XtremeSound XS71 7.1 Channels 24-bit 96KHz PCI Interface Sound Card - $29.99
    HITACHI Deskstar 7K1000.C HDS721010CLA332 (0F10383) 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive - $54.99
    Microsoft Windows 7 - $109.99
    Monoprice:
    6ft 28AWG HDMI DVI Cable w / Ferrite Cores ? Black - $3.71
    Total before shipping: $351.65
    Is it worth upgrading? Another option would be the WD TV Live Hub. Has a terabyte of storage, plays just about anything, for $200.
    Hope this helps. Good luck!
    polk monitor 70's
    center - polk monitor cs2
    surround - polk monitor 60's
    surround back - jbl e10
    sub - velodyne dps 12
    sub - polk psw110
    avr/pre-amp - onkyo tx-nr809
    amp - adcom gfa-5500
    amp - carver av405
    display - sharp lc70le847u
    tv - silicon dust hd homern
    blu-ray - oppo bdp-103
    hd dvd- toshiba hd xa2
    control - logitech harmony one
    turntable - technics sl1500 mkII
