Doro, i need shrink tube links LOL
faster100
faster100 Posts: 6,124
Hey, i think it was you that gave me the tech flex link and the shrink tube links.. if you have them handy let em fly.. i will also try and do some research on yahoo.. I just want the same place so i know other people have dealt with them.. Thanks a bunch.
I finally ordered my Monster lock banana's today for my Monster 14-4 bi-wire on the mains, ordered my csi30 center last night for rear duty.
edit: parts express carries it, so what size would fit good for Monster 14-4 bi-wire?? and do they also have shrink tube??
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by RyanC_Masimo on
  • dorokusai
    dorokusai Posts: 25,577
    edited August 2003
    Faster - Actually I think that was someone else, but I have used that before.
    I purchased mine thru www.frozencpu.com , so check them out.
    They have multiple colors, UV reactive type, etc.
    I picked up some extra heatshrink from Home Depot, in the electrical aisle.
    I can't remember that link either, but the above link will get you the same stuff.
    LOL:cool:
  • faster100
    edited August 2003
    Hey, great!! does home depot have colors?? in the heat shrink?
    do you know what size tech flex fits the 14-4 wire?
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • dorokusai
    edited August 2003
    Home Depot only has black, FrozenCPU has colors for everything in sleeving and heat shrink.
    I am not sure what wire you mean exactly, if it is smaller than your pinky, get the 1/4"....larger than your pinkey, get the 1/2". You could also look in your computer, the power supply bundle needs 1/2", everything else uses 1/4".
    Hope this helps.
  • faster100
    edited August 2003
    It sure does, thanks .. the Bi-wire is that white plastic coated covering stuff that monster has, Bulk 14 awg 4 conductor.. its smaller then my pinky
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
