get a svs or add
john Jarvis
i have a 19 by 16 room that opens to the kitchen.
my set up is
rti a7's
csi a6
fxi 30's
rti 38's
dsw pro 400
yamaha rxv-663 7.2
what my question is i am looking at getting the svs PC12-NSD or would adding a dswpro 400 work? i use my setup 60/40 movies/music.
i am looking for more punch i guess.
my set up is
rti a7's
csi a6
fxi 30's
rti 38's
dsw pro 400
yamaha rxv-663 7.2
assuming ceiling is 8' you have about 2500 cubic feet not counting the opening to the kitchen.
If you sub is located in the corner I would just add another 400 or sell the one you have and go with one large sub.
AGain, you are just guessing until you understand what your room is doing.
If you are serious go to hometheatershack.com and get your read on using REW, Room EQ Wizard.Speakers: SDA-1C (most all the goodies)
