Adhesive to reattach mw7100 butyl surround
quadzilla
quadzilla Posts: 1,543
edited February 2011 in Vintage Speakers
So I had this other thread where I thought I'd blown a driver due to hearing some rattling/buzzing/distortion from one of my LS50s. The good thing is that I ended up meeting Dave, which in and of itself makes it worth it.
But what I happened to find out today, about a month later, is that the problem is actually that the butyl rubber surround has separated from the cone in a few places. So any recommendations on the best adhesive to use to reattach the surround and let me save these drivers? The VCs should be ok, because I played them neither loud nor long once I noticed the problem.
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Post edited by quadzilla on
  • brgman
    brgman Posts: 2,859
    Henkel Loctite makes a product #1050904 i believe.Look on Amazon.
    And let us know how it works if you try it.
    I’M OFFENDED!!!!
  • luv-my-ls50
    luv-my-ls50 Posts: 7
    Thank you quadzilla for starting this thread. I've pulled the MW7100 driver out of the LS50 again to re-examine the surround. I have GENTLY pushed a narrow screwdriver against the foam from the back of the driver trying to find exactly where and how much the foam has separated from the cone. There seems to be about 1/4 inch of overlap or seam where the surround glues to outside of the cone. Slightly touching the surround while the speaker is playing softly greatly exacerbates the buzz for about 40% of the way around the driver. putting slight pressure against the cone toward the side of the basket away from the 40% area almost completely stops any sound from coming out of the driver when playing softly. Does this mean that I've already suffered voice coil contact with the magnet and that the varnish has been rubbed off the VC and that is the reason the driver stops playing when gentle lateral pressure is applied to the cone?
    Thanks, Dana Burkley
    Warning: I suffer from the delusion that knowledge will solve my problem.
  • luv-my-ls50
    I Googled "speaker surround glue" and went to a Klipsch forum. One guy suggested "Weldbond". Another suggested "methyl methacrylate" which is some kind of a specific glue that is meant exclusively for speakers. Most of those guys like silicone. Many have used it and say it works.
  • silvertuner
    silvertuner Posts: 496
    i have used weldbond and had good luck. i do not use it for redoing entire surrounds, but in a crunch (and its cheap) and for a quick fix i have used weldbond and it has given me good results everytime
    some cheap free sony speakers
    psw125
    denon 1610
    3.1 channel because i hate cables ran across the living room like that
  • quadzilla
    Try gently pushing on the front of the cone near where the surround meets. If you see a gap open up, the surround has separated. If not, then you've got a different problem than I do.
    As far as whether you've damaged the VC, it's doubtful. But you can check to see if the VC is shorting by checking with an ohm meter. Both mine read 6.6 ohm. Make sure you disconnect the driver before checking.
    Arm: Rega 300
  • ben62670
    ben62670 Posts: 15,969
    SuperGlue. Don't use it with foam surrounds.
    Ben
  • civilian
    civilian Posts: 357
    Coming from an RC background there is foam safe superglue fwiw.
    ________________
    2 Channel-Denon AVR-4520/SDA 2.3TL's
    5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/
  • quadzilla
    ben62670 wrote: »
    Hmm... you know, I hadn't thought of superglue. I had it in my head that I'd need some sort of special adhesive for a surround due to all the flexing and vibrating. But yeah, they have flexible cyanoacrylate formulas out now.
    Arm: Rega 300
    Tony M Posts: 11,631
    How about that Aileens tacky glue?
    I think it works wonders for other speaker surrounds.
  • quadzilla
    Thanks. Never heard of Aileen's. I'll look into it.
    Arm: Rega 300
  • gdb
    gdb Posts: 6,012
    You can buy a tube of butyl caulking compound that when cured, is butyl rubber. Usually used for seams in aluminum rain gutters.:wink:
  • ben62670
    I have used super glue for surround and spider repair. It is fine to use the regular stuff. It doesn't really dry that hard, and it drys fast.
    Ben
    Sorry, I miss-spelled the name. I just went to a craft store and bought some and noticed the spelling. Here it is. They also had a bunch of other aleene glue that I didn't know they made. I also bought some of their clear thick set glue for anchoring port tubes on an old Pinnacle sub I bought last winter.
    http://www.save-on-crafts.com/alortacglu.html
