Someone to split a 2m cable into 2 x 1m RCA
moggi1964
I have a Noble Cyprium 2m cable that I would like to make into 2 x 1m cables and I do not have the soldering equipment or skill.
Is there anyone who could do this at a reasonable cost?
Thanks.
Thanks.
Magnavox 185 modified amplifier
Vista Phono+
Technics SL-D2 with ADC XLM MKII improved/AT440OC
Polk Monitor 70 + CS2
Vista Phono+
Post edited by moggi1964 on
I can do it for you for cheap, but the issue is going to be the connectors. Since Noble doesn't sell their connectors as far as I know, I would have to use different ones which would sound good, but wouldn't match. If you don't mind the connectors and heat shrink not matching, let me know and I'll be happy to rebuild your cables for you.
PM'd you ZingoMagnavox 185 modified amplifier
Vista Phono+
Polk Monitor 70 + CS2 -
Vista Phono+
SortedMagnavox 185 modified amplifier
Vista Phono+
