Hookup Wire
intangible
intangible Posts: 262
edited February 2011 in DIY, Mods & Tweaks
Any recommendations for purchasable, reasonably priced hookup wire, preferably shielded (space is a little cramped inside the chassis and it will be difficult to separate the power and output lines) and not silver (I don't have the equipment to solder it)? Google picks up some recommendations, but it's all sold by the mile or so, and I only need a yard or three. Thanks.
Post edited by intangible on
  • zingo
    zingo Posts: 11,258
    I just bought a bunch of DH Labs BL-1 three conductor and shielded signal cable to use to wire my amp. It's stranded, silver coated wire that's very easy to work with and is purchased by the foot directly from DH Labs in Florida. I also picked up some non shielded wire from them for other runs, and am excited to hear the results.
  • Systems
    Systems Posts: 14,872
    Sonic Craft sells several brands (Cardas, DH, ect.).
    I have read good things about the Neotech, but have not tried it myself.
    Heres the link:
    http://www.soniccraft.com/products/wire/chassis.htm
    Testing
    Testing
    Testing
    F1nut Posts: 52,159
    Furutech makes great hook up wire. I'm not sure I've ever seen shielded hook up wire.
  • headrott
    headrott Posts: 5,496
    I have used Neotech hookup wire (mostly for power lines) and it seems very good. I bought some VH Audio Unicrystal OCC hookup wire for the analog and digtal lines in my DAC. It is very nice wire and I highly recommend it. Located here: http://www.vhaudio.com/wire.html
    Greg
  • fbm211
    fbm211 Posts: 1,488
    Furutech hookup wire is great stuff if you dont need much.I was going to rewire my 2Bs with the alpha stuff but parts connection raised the price from 4.95 per foot to 40.00 + per meter.
    UPDATE
    Now its down to 18.40 per meter for the 16 awg.Thats more resonable so Im considering it again.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • Face
    Face Posts: 14,340
    I'm a big fan of Neotech. Cardas has a little more of a relaxed sound to it, but it's a PITA to work with.
  • fbm211
    fbm211 Posts: 1,488
    Is that neotech (copper) sonic craft sell stranded or solid.?
  • intangible
    Thanks for the suggestions, guys. Let me make sure I am asking for the right stuff before I buy anything, since I thought using shielded wire was pretty common. I'm building an amplifier and need wire to connect the transformers/inputs/binding post/switches to the PCB.
  • Face
    Face Posts: 14,340
    fbm211 wrote: »
    Solid.
  • zingo
    zingo Posts: 11,258
    On my last tube amp, I used shield wire on runs past any transformers and it did make a difference. On that amp I used Canare L-4E6S Star Quad cable for the signal wire as it has a shielded and double twisted design; worked great for not being expensive.
