LSi9 Amp Requirements
IRLRaceFan
IRLRaceFan Posts: 172
edited February 2011 in Speakers
So I'm weighing my tax return options over a possible speaker purchase and LSi 9’s are on my list.
One of the things I’m wondering about is amp requirements. What does it take to run these and will my Emo UPA-1’s be good enough?
I know there are better amps out there; but since I don’t have a tree in the backyard growing $$$, speakers AND another amp is not going to happen. Music is the main consideration and I do play it loud at times, but plan to keep the knob under 11.
So for the sake of this discussion, will LSi 9’s sound good with my current equipment? Or should I buy another amp(s) first and think about these speakers latter? Also, what about speaker wire? Do I really need to spend $100+ per foot for these??
(I'm very skeptical about high priced wire, but maybe it makes a difference w/ 4ohm???)
Thanks in advance! :smile:
Shaun
HT
Onkyo TX-NR1008 | Magnepan 1.7 | Polk LSiC | Polk VM20 | Polk DSW microPro 2000 | Parasound HCA-2205A | Oppo BDP-93
2-Ch
Cary SLP 30 Tube Preamp | Polk LSi7 | Carver M1.5t | Audio-gd Digital Interface | W4S DAC-2 | MAC Mini | Denon DP300f & Pro-Ject Debut III TT's
    EndersShadow Posts: 17,753
    IRLRaceFan wrote: »
    Should be fine
  • cfrizz
    cfrizz Posts: 13,415
    You should be just fine with the Emotiva powering the LSI 9s.
