Polk Logo for Monitor 10B
Jack A
Dose anyone know the correct placement for the Polk logo on a Monitor 10b. I have one speaker logo missing, is it on the grill or on the lower part of the cabinet?
Thanks for your help Club Members.
Clarajack
Post edited by Jack A on
I believe it depends on which cabinet you have. Some have maybe 1/2" wood below the grill and logo went there. On others the grill is almost flush w/ top and bottom and the logo went on the grill bottom right IIRC.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
I believe it depends on which cabinet you have. Some have maybe 1/2" wood below the grill and logo went there. On others the grill is almost flush w/ top and bottom and the logo went on the grill bottom right IIRC.Clarajack
They go on the bottom right. Look at the back of the grill frame, you should see one small hole there.Political Correctness'.........defined
