Thiel speakers
Timothy Smith
Timothy Smith Posts: 764
edited February 2011 in Vintage Speakers
Anyone have any experience, or opinions on Thiel speakers?
I am considering buying a set of used Thiel CS1.6's, but have not listened to them yet.
Thanks,
Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
Post edited by Timothy Smith on
  • xsmi
    xsmi Posts: 1,801
    They are VERY revealing! Some say they can be a little lean but I have only found that with bright recordings. make sure you have excellent electronics and you are in for a REAL treat.
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • Face
    Face Posts: 14,340
    They have a nice sound to them and image well, but can sound a little forward with the wrong gear.
  • Timothy Smith
    I currently have a used Antique Sound Labs Line One tube pre powering a 200 wpc Rotel 1080. The little inexpensive ASL sounds great to my ears, especially after I swapped the single stock ElectroHarmonix 12AU7 tube with a RedLion tube.
    If the Thiel's don't need much power, I also have a Cayin TA-30 integrated that I think sounds nice.
    Tubes seem to "tame" otherwise bright or forward speakers that I didn't like so much with only/all SS amplification.
    Thanks for the help!
  • thuffman03
    thuffman03 Posts: 1,325
    Thiel speakers are very good. I had a set of CS3.5.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Ricardo
    Ricardo Posts: 10,636
    I owned a pair of 3.6's and really liked them. The only reason I got rid of them is that my room was too small for the "size" of the sound. The added gain to the bass was too much and no treatments could control it. They are very revealing as everyone has said, but with my gear at the time they were not harsh.
    SOPA
