Musical speakers
photocrazy
How do you qualify a musical speaker ? is it just the tweeter ?
Post edited by photocrazy on
Does it sound good to you?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Nope, music is not just in the highs. It's a complete package. A musical speaker performs well with music. This is mostly subjective, but there are certainly some speakers specifically dialed in for theater like the RtiA9s, or by contrast the Lsi15s which are specifically dialed in for music. I'd take the Rti series over the Lsi series for movies, but again that is subjective.
Compared to many speakers the Rtia9 is very musical, but compared to my old Emerald Physics CS2s, the Rtis are a dog. But, that's not a fair comparison anyway. Just find your reference for what you consider to be good sound, then move up and down from there. -
Driver selection, ability of the crossover to blend seamlessly, maximum reduction of cabinet resonances, smooth frequency response.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
RuSsMaN hit the nail on the head.If you can't hear a difference, don't waste your money.
I define a musical speaker as one that I can listen to music that utilizes the high's, mid's, and low's, and I do not hear a difference. My Sony's, to me, are flawless. I listen to Track 6 of DMB Crash Album (Say Goodbye) and the drum/flute solo at the beginning gives me chills every time. The drums are so lifelike because I hear the hi-hat, tom, snare, and bass drums - and they sound so natural. Seamless.
James2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player -
That's true, what's musical to you might not be that to me. For me it has to be smooth, mellow, non-strident up top, clean vocals, and punchy bass and overall SOLID weight of sound when properly amplified. In addition should have good imaging and fairly accurate sound-stage.
However a lot of speakers have that and I like some and dislike others. It's certainly not all about the tweeter..though a BAD tweeter automatically brings a thumbs down from me, personally. If it's too bright or dull, that is.
Maybe it's too simple, but I often refer to some speakers as being, or sounding, musical:
What I mean is that they sound like music, not like speakers.Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player -
so I assume a musical speaker should be neutral and reproduce sounds as close to original instruments.
The reason for my question is I read a lot that Polk Lsi is a musical speaker, when RTis are not. -
photocrazy wrote: »so I assume a musical speaker should be neutral and reproduce sounds as close to original instruments.
Pfftt...
Depends - the ear of the listener being one, among other factors such as musical preferences, system synergy, etc.
RTis can do music quite well - have had both LSi and RTi.
I think the whole concept of calling a speaker "musical" probably stems from the introduction of cheap home theaters that feature far less-than-stellar speakers. They tend to be zippy in the treble, not have very good driver integration, and the cheapest crossovers; not to mention sub-par cabinet construction. They are built for the general public, with not much interest in winning over audiophiles. Like the stock radio in a new car, it'll work, but don't expect to be amazed.
Though higher quality HT speakers are blurring the lines now, some feel they are voiced more for the "wow" effect, and less for strict music listening.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
