Simple Bedroom System
bobman1235
bobman1235 Posts: 10,822
edited February 2011 in The Clubhouse
For a while now I've wanted a simple 2CH system in my bedroom.
I know it's not fancy, certainly not compared to what most of you have, but finally after purchasing the H/K from stangjason for H/T duty last week I was able to retire my Denon to my bedroom along with an old pair of R20's (the very first Polk speakers I bought and the ones that brought me here in the first place, in fact).
Last night I just laid in bed and listened to music before going to sleep. It was fantastic.
Post edited by bobman1235 on
  • seeclear
    seeclear Posts: 1,242
    It doesn't need to be fancy. What is important is that it can work for you, give you some enjoyment, and it sounds like it does that, in spades! Relax and enjoy it.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • Knucklehead
    Knucklehead Posts: 3,602
    Music sounds fantastic to me at low volumes through my Warfdale Diamond II's when Im just relaxing in my home office.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
    Same here. Simple HT set up in bedroom: Onkyo TX-SR604, two Rti-4s and one 8" 100 watt RMS sub. Toshiba HD-DVD player. In a small room with Onkyo's Theater Dimensional (wide) option it does the job and more! Highly recommend a similar set up to anyone with a smaller bedroom who wants a 'simple system that sounds good'.
    cnh
  • steveinaz
    steveinaz Posts: 19,538
    It's all about the music, I can enjoy listening to a transistor radio at times....
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,726
    There are lotsa options out there for good low cost monitor type speakers out there too, so if you decide an upgrade is in order you'll have options.
