speakers and wiring for mmats d200hc amp?
Systems
I have a MMats class D amp model number= d200hc. It is 1ohm stable with two channels. I recentely had 4 polk dx 10" speakers running off of it. two speakers were run in parallel off of one channel. To cut the story short a couple of my speakers are blown and I want to get new speakers. I really want to get the most bass I can from this amplifier. What kind of speakers would be good for this amp? I was thinking about two bad **** 12's or 10's. Any advice would be greatly appreciated.
Testing
Testing
Testing
Testing
Testing
well how much power does the amp do???
assuming it did enough for 4 dx 12's then i dont see why you cant run 4 momo 10's or maybe 4 momo 12's.The Artist formerly known as PoweredByDodge -
The amp is rated at 1200 watts at 1 ohm. But I am sure it is underrated as it blew some of my 10's. I would really like to get two speakers instead of four because I have limited trunk space. Do you know of any speakers that would wire up to 1 ohm and take the power of this amp so I would only have two speakers in my trunk instead of four?Testing
Testing
Testing -
two subs at 1 ohm and 600+ rms each...
- alpine type R 12" swr-1241D
- alpine type R 15" swr-1541D
- image dynamics idq 15" v2 d4
- phoenix gold titanium 10" dual 4 ohm coil
- phoenix gold titanium 15" dual 4 ohm coil
- rf punch hx2 12" dual 4 ohm coil
- rf punch hx2 15" dual 4 ohm coil
- xtant x 12" dual 4 ohm coilThe Artist formerly known as PoweredByDodge
