Energy RC Speakers and Pioneer VSX-1020-K
Kabigon
I would prefer the Rosenut finish on the speakers, but will consider others, as well.
Here is a list of the Speakers I am looking for:
Energy RC-50 x2
Energy RC-LCR
Energy RC-10's x2
Here is the Receiver I am looking for:
Pioneer VSX-1020-K
Obviously, I don't mind if they are Used or Refurbished as long as they are in mint condition both functionally and cosmetically.
Thanks!
Energy RC-50 x2
Energy RC-LCR
Energy RC-10's x2
Pioneer VSX-1020-K
Thanks!
Post edited by Kabigon on
Found an incredible deal on 2x Energy RC-R's for my Surrounds so I am going to go with those instead of the RC-10's because they should be much better for Surround since that is their actual purpose. ^_^
Still looking for the RC-50's, RC-LCR, and the VSX-1020-K.
I also need a set or two of Macromount Brackets if anyone has them for sale. Thanks! -
if you don't need the (minor) swivel adjustment that the macromount brackets provide, why not just make a simple "french cleat' to mount the rd-r's to the wall? i think a french cleat makes for a much more stable mount and since it is the width of the speaker it is also easier to position the mount where there is a stud in the wall. if you don't know what a french cleat is do a google search for it. you can make them yourself for practically nothing and they are a lot more solid than any stand off mount and that translates into better sound.
