rubber surround on sub
dholmes
dholmes Posts: 1,136
Does anyone know if there is a subwoofer with soft rubber surround on the woofer ? the old ar that I have sounds okay but the surround on the spk is that stiff foam type of surround, it could be better . thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • rs159
    rs159 Posts: 1,027
    edited August 2003
    Could you explain your situation? Is the surround rotting away? Do you need a replacement driver?
