What model Polk speakers are these?
Rookie
Rookie Posts: 20
edited February 2011 in Vintage Speakers
What model Polks are these? The seller said '93-'94 Monitor series 2 but I can't find any info on them... What are they worth?
I'm always looking to upgrade my current system. Would these be a upgrade from 1985 SDA2's?
http://milwaukee.craigslist.org/ele/2196925317.html
Post edited by Rookie on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Monitor 12. Decent model, not one you see everyday.
    Cheers,
    Russ
  • ben62670
    ben62670 Posts: 15,969
    Those are Monitor 12's. The ~M~ cable is not worth anything, and I don't know the value on the other gear. SDA2's setup properly would be better. Which SDA's do you have? The side by side tweeter, or the vertical tweeters?
    Ben
    Toolfan66 Posts: 17,338
    $1100?????:rolleyes: Dude is on crack, I would take a set of 7B's or 10's over those..
    Keep your money!!
    Edit: I just saw the other gear!!! Not sure what they are worth.
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • Rookie
    Rookie Posts: 20
    Thanks for the good feedback.
    txcoastal1 Posts: 13,338
    txcoastal1 wrote: »
    Still not worth it IMO!!
    SVS SB16 X2
  • Rookie
    Rookie Posts: 20
    What are the 12's worth?
    What are my SDA2's worth? they are in good shape with all drivers working [they are the first style 2 tweets 3 drivers]
    I don't have the interconnect cable, called polk blade style and they have them for $50
  • ben62670
    You need to mention that you are a Club Polk member to get that cable cheaper. IMO the 12's are worth $250-300 in very good shape, and those 2's are worth $300-$350 in very good shape.
    Ben
