Center channel help, and rears help
ShadowTowel
Hi everyone,
I currently have the following setup:
2 TSi100's in front
2 RCi60's in rear
1 CS10
1 PSW10 and 1 BIC Acoustech PL-200
Denon AVR-590
I am upgrading my fronts to RTi A3's next week. Big upgrade I think. But do I need to upgrade my cc pronto?
And if so, to what? Must be no more than 22" wide!!
A) CSi3 ~ $120
CSi A4 ~ $230
C) KEEP THE CS10!
D) Other Center (please name one if you think I should do this)
Let's keep the cost around 300 too. Or less!
Thanks guys!
Also, would the TCi60's be worth the 300 or 400 to replace my RCi60's? I can't imagine them making that much difference in my system. Anyone ever experienced that upgrade?
2 TSi100's in front
2 RCi60's in rear
1 CS10
Denon AVR-590
A) CSi3 ~ $120
C) KEEP THE CS10!
Thanks guys!
Polk Audio RTi A3 (mains)
Polk Audio CSi A4 (center)
Polk Audio RC60i (rears)
BIC Acoustech PL-200 (sub)
Denon AVR-590 (receiver)
Samsung LN46B550 (LCD)
Sharp BD HP22U (Blu-ray player)
Post edited by ShadowTowel on
csi 5 is a great speaker,Parasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC -
Isn't that extinct and more than 22"? I remember thinking it was similar to the CSi A6. Not positive though.Polk Audio RTi A3 (mains)
Sharp BD HP22U (Blu-ray player) -
Hey guys, I really could use help because I'm probably getting my RTi's tomorrow. Please let me know regarding the center channel. I know some of you guys have made similar series upgrades...Polk Audio RTi A3 (mains)
The CSiA4 is $179.99 at polk direct on eBay if you want to save some money.Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player -
I upgraded to the CSi5 from the CSi3 and definitely enjoyed the improvement.. CSi5 is a far better speaker.. haven't heard the newer CSiA's though.. but I would recommend against the CSi3 compared to the other options..
Jason2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
The Polk CSiA6 would be your best choice as it has the same size drivers as the RTiA3 Bookshelf Speakers. And the Center is a Very Important speaker.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects -
Well I would love to get the csi a6 but it is 2" wider than I can fit in my room. So csi a4 vs. csi3? Or keep the cs10?Polk Audio RTi A3 (mains)
^^^ I'd go with this over the CSi3... Then everything would be all pretty and match.
In the end, though, shouldn't be much difference either way.
The biggers are better, but if they don't fit, it don't matter... -
mdaudioguy wrote: »^^^ I'd go with this over the CSi3... Then everything would be all pretty and match.
Thanks, do you think the csi a4 would sound much better than the cs10? I ask because it ISN'T an upgrade in size. It seems like a lateral move. Is it just the sound quality will increase since it is a higher quality line?
I know the timbre matching is important, I just wondered if that was the only improvement or if it was a step up all around.Polk Audio RTi A3 (mains)
Anyone? Looking to purchase this week. Curious if it is worth it, could save me some money.
Cs10 to csi a4Polk Audio RTi A3 (mains)
Thanks dskip, I appreciate the response. If the increase will be similar, I am sold!
I wasn't sure how much of the increase in quality between my tsi100's and rti a3's was due to the increase in driver size, and how much was due to the series jump.Polk Audio RTi A3 (mains)
